Thread: servo cables?
    Thanks MC and Boyan
    Wishing I had got the solder version now. Did you connect all the wires or just the ones you need?
    Do you have the user LCD for programming? I don't so not sure how to set it up.
    Thanks MC and Boyan
    I made longer 3 of the wires and soldered all the connectors inside. As main problem here is i live 200m from sea and typical humidity is 85% so even crimped connections will fail sometimes.
    When i connected 2 cables together and used heat shrink tubing on each core, then i cut in half a proper size silicone tube. Fitted the connection there and potted it with hot glue gun.
    You dont need LCD. You need a computer, serial port and special serial cable, check manual of what variety it was, as i remember i needed different variety for the Galil controller.
    Samsung servo software is free and self explanatory. For the Galil servo control software you have to pay some 2xx euro additionally for example hence, that's why i said before buying servos check if servo software is free like the Samsung one.
  3. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. Replacement cables
    By Paul B in forum Chinese Machines
    Last Post: 25-04-2017, 11:24 AM
  2. eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
    By dazza in forum Items On eBay UK
    Last Post: 29-01-2015, 08:55 AM
  3. FOR SALE: Pack of Omron servo drivers + cables
    By albertoro in forum Items For Sale
    Last Post: 25-01-2015, 12:19 PM
  4. Which cables to shield?
    By andy586 in forum General Electronics
    Last Post: 02-07-2014, 04:33 PM
  5. USB repeater cables
    By Web Goblin in forum General Discussion
    Last Post: 21-05-2011, 12:36 PM
