Page 4 of 14 FirstFirst ... 23456 ... LastLast
  1. #31
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    The Cetus3d looks really good but resisting the urge to say "I have all the parts to build that...."
    the only down side is that it will only do PLA. Do you guys use nylon much or is it really difficult to do the engineering plastics?
    Agreed, for that money, its not worth the time to design, buy, build and test IMHO.
  2. #32
    Any idea how much to import it though? not available yet either.
    I'd recommend a prusa www.prusa3d.com
    I have the previous to the last model and works like a charm. With the new one they have won best printer of the year and looks like a really good printer on a budge
    That one is about £1k, are the clones as good?
  3. #33
    Chaz's Avatar
    Speak to AndrewMawson on here, he imported one.
  4. #34
    I'm currently using PLA (and some ABS for tougher small parts) on my (£275) Pusa i3 clone kit, I'm in the process of modifying for Nylon and for larger ABS parts as I have product designs for parts which require the better engineering plastics with higher glass transition temperatures and better durability than PLA.
    - Nick
  5. #35
    Hows this one if I go the Purusa route http://factory3d.co.uk/
  6. #36
    That's the one I went for, I don't think you can beat it for the money and support is excellent via email and telephone, Neil from Model Engineer has that one too, have a look at his posts over there.
    - Nick
  7. #37
  8. #38
    This Prusa is crazy cheap I'd just buy this if I were you.
    http://www.ebay.co.uk/itm/2017-Upgra...3D272622069677
    Add auto levelling for £2
  9. #39
    I like the look of the Wanahao.
    I'd avoid plastic framed printers like the plague, Aluminium or Steel construction at least means you have a good base for a rebuild or upgrade project at some future point.
    Nozzles and Throats which aren't commonly available as generic spares are a bad idea as are machines not running the most popular open-source firmware versions.
    Printers with the hot end and nozzle very close to the extruder drive may well prove problematic should you wish to print one of the more flexible filaments,
    - Nick
  10. #40
    Some of the cheap ones are not even plastic, but thin plywood.
  1. Who is Denford 3D Printer?
    By g20hz in forum Denford 3D Printers
    Last Post: 25-09-2016, 10:33 AM
  2. A3 printer plotter
    By gatesy in forum Machine Discussion
    Last Post: 21-12-2015, 04:19 PM
  3. New toy, Afinia 3D printer
    By Robin Hewitt in forum 3D Printing Machines
    Last Post: 05-07-2014, 11:18 AM
  4. eBay: 3d Printer project!
    By andrewbond in forum Items On eBay UK
    Last Post: 11-05-2013, 08:07 PM
  5. robuster 3d printer
    By wilfy in forum 3D Printing Machines
    Last Post: 06-04-2013, 11:51 PM
