I'm not sure I understand what angle you refere to... If it's about the gantry weight distribution to the X axis glides assemblies, the answer is at a few SW clicks distance. Make sure you have set the actual material/ mass of the components then look at the center of gravity. It should be close to the center of the X axis bearing blocks assembly in the vertical plane perpendicular to the X axis.
06-08-2017 #2
07-08-2017 #3
Many thanks, i appreciate the advice, i will bear that in mind about the end machining i did not consider that before, only that they might be bent!
Hi Clive, thanks for the pointers! I have as you said decided not to buy the kit, the saving was insignificant and i did not want to be using that breakout board they were supplying anyway. I also questioned why they supply a 36v PSU with the kit, when you look at their higher volt PSU's it states that they are not compatible with the Drivers supplied in that kit...? Seems iffy to me, maybe the drivers are cheap and can't run at the stated specs. I will probably go for those drivers you have mentioned if they come with good recommendation.
Not sure i feel comfortable building my own PSU haha, i will try to find a higher quality alternative.
Ok so, when building my last 3D Printer i had used a chap on Aliexpress to provide me with the ballscrews and everything else associated with them. I compile a list of what i needed this time and first priced it from the UK, so i had a list of what i needed which was going to come to about £690 + Delivery here in the UK, went to aliexpress and returned to the guy who supplied me before and sent me this quote back:
2 x SFU2010- 1200mm with 2pcs nut with end machining=$42
3 x Set BK15 BF15=$24
3 x DSG20H=$6
3 x XB30x40-8x12=$8.46
1 x SFU2010- 712mm with 1pcs nut with end machining=$16.46
1 x SFU1605- 362mm with 1pcs nut with end machining=$10.2
1 x DSG16H=$1.21
1 x Set BK12 BF12=$6.22
1 x XB30x40-8x10=$2.82
Price is $117
Shipping costs is $100 by fedex to UK
Total is $217
Now i honestly could not believe how cheap that was, if i ordered today it would be £166. I got a price from another supplier on there and they quoted ~£340 delivered, would your guy be anywhere near this do you think? Even if they were bent there would be lots of room to play in terms of having them straightened at that price.
Spindle wise, i was going to go for this, unless someone has experience with another:
Click Me
Thanks for the other tips about the motors etc, i like overkill so i think i will stick with them in case of any future needs.
See Below
Yes i like the idea of Aluminium so i think i will definitely go with that after hearing that, proximity sensors are good for me and they are cheap too so i will incorporate them.
I have found a controller that i think i am now going to use:
DDCSV1.1 Controller
I like the idea of just being able to run files external from the laptop so if it's as good as some of the reviews say it is (for the money) then i will probably go with this. I also liked what this guy did with it:
Brainright
Ok, so the Axis is orientated as is to try and get the maximum workable area within that size of frame, i could have made it more central "looking" but in reality its not really central because on one end of the axis the spindle can reach past the machine, and on the other end you have a few hundred mm of area that you cannot reach, this is why i have tried to balance it and make the most of the space available. I'm nt sure of the weight of the spindle but this is obviously very important in order for Solidworks to calculate the centre of mass, i had read online that in general a 2.2Kw spindle will weigh in the region of 5Kg. So i set that as the mass of the spindle and run the evaluation, and it came out pretty well imo, more than acceptable to me, the linear rails and carriages im using are supposed to be high quality so im hoping that they will be fine:
EDIT: Just realised that picture isn't so great, the Centre of Mass appears to be just in front of the left side carriage block, and it also shows a slight angular (right word?) pull, twisting towards the rear of the X Axis. Possibly i could move the right carriage block towards the middle some? This would seriously hurt my OCD of having them space equally.
Thanks Again for all the replies i've already learnt alot so keep that criticism coming :D
AlexLast edited by AlexDoran; 07-08-2017 at 10:10 AM.
07-08-2017 #4One similar to this http://www.zappautomation.co.uk/elec...er-supply.htmlNot sure i feel comfortable building my own PSU haha, i will try to find a higher quality alternative.
Re the spindle make sure it is the correct vfd check the picture and make also 4 bearings
http://www.ebay.co.uk/itm/WATER-COOL...kAAOSw0e9UtOrX
Re the controller will it home two screws with independent homing? Will it cope with full Gcode G2 G3 , canned cycles etc. What size gcode file can it handle? (I have no experience with these but they have been debated on the forum)..Clive
07-08-2017 #5
Hi Clive,
Thanks for the PSU link, says they are out of stock but i can look for a similar item based on that.
Sorry for my lack of education, what do i need to look out for when it comes to the VFD? What differentiates between the correct & incorrect one?
I am not sure about the independent homing, i will need to check that for sure, is this common practise for machines with multiple screws on one axis? Is this to ensure they stay parallel? I believe it can handle full GCode list, need to research canned cycles, apparently it can handle any file size because it reads from the USB stick as it goes.
Unconvinced with my result from the Centre of Mass evaluation i done, i got on the phone to Solidsolutions, who provide our solidworks license and also provide support, indeed i had done it incorrectly. Here is where the actual centre of mass is on the gantry. It's hard to see, but where it says "Point 1".
Not sure how much of a problem this poses, are the carriages likely to be affected by this? Not how i might remedy this other than reducing the Gantry to a single 40x40 extrusion as opposed to 40x80 and then centralising over the Gantry Base Plates further. This in turn might affect how rigid the gantry is surely?
AlexLast edited by AlexDoran; 07-08-2017 at 12:14 PM.
07-08-2017 #6
VFD's are rated for certain motors. So you might have a 2.2kw motor rating and such you will require either a 2.2kw VFD or higher but it's best to use the same rating. Now what I've been having issues with it my VFD has been nuisance tripping my RCD and thus now having a none RCD circuit wired in to my workshop to stop it due to the current load on startup. Also, go for a water cooled spindle, your ears will thank-you afterwards!
Rob
07-08-2017 #7
Hi RobC,
Ahh i see, that makes perfect sense, i just didnt know if there were different types that affected compatibility with other hardware. I have asked the seller a question about how many bearings it has. One thing i am curious about, and that i have done no research on, so am lazily asking you guys. The VFD's do you set their speed manually? On our CMS Machines at work we set all of the within the CAM program, its not a problem if this speed is set manually i was just curious.
Alex
07-08-2017 #8Ok look at this link it shows the difference in the types of the standard vfd. LOOK at the front of them that is the best way to tell they have a different layout you want the Huanyang inverterSorry for my lack of education, what do i need to look out for when it comes to the VFD? What differentiates between the correct & incorrect one?
http://www.ebay.co.uk/itm/TOP-2-2KW-...EAAOSwHnFVvvsm..Clive
07-08-2017 #9If you are using two screws and two motors you will have to use two home switches to make sure the gantry is put square every time you home.I am not sure about the independent homing, i will need to check that for sure, is this common practise for machines with multiple screws on one axis? Is this to ensure they stay parallel
You can of course use two screws with one motor and a belt driving both screws then one home switch will be fine.
The choice is yours as there are pro's and con's and much debate between the two types.Last edited by Clive S; 07-08-2017 at 02:58 PM.
07-08-2017 #10
Ok, i need to do some serious research to see if that controller can handle that, i know it provides for 4 Axis but im not sure if the 4th can be setup as Dual Axis.
So i know i keep banging on about the weight distribution of the Gantry, but i really am being stupid today. It seems at some point i had lost all of the material properties for my assembly parts, ive just spent a little while going through and properly setting the weights of each component, i have based the Aluminium Plates on being a 6061 Alloy, whether or not this will be the material the plates are cut from i dont know, but it was the most common material so i though i would go with that, i re rain the analysis and it has given me a hopefully accurate Centre of Mass for the gantry, indicated by the Red Dot, im hoping this is a pretty acceptable balance and wont cause any undue wear or stress to the linear bearings:
Alex
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Building a plasma table, need advice.
By superclarkey in forum Plasma Table MachinesReplies: 37Last Post: 20-09-2016, 04:57 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM
