    I Have a Isel CPM 2018 thati have converted to run with Mach3 on it is a Isel UFM 500 ut it dose not have any collets oe a clamp nut, I have bought 2 different nuts and a set of ER11 collets, none of which fit the collets are the wrong taper and the nuts one size is too small and the thread on the other seems wrong like one is a taper they are CNBTR 11 A and other is CNBTR 11 M
    dose any one have any Idea what collets and nut fit this spindle are they Kress? or do i just buy a chineese air cooled brushless??? or maybe a new Kress 800 or 1050 about same money
    Thanks for any help
    Steve
ID:	22712 Click image for larger version.
    yes got google but that tells me nothing, if you cant say any thing helpfull why say any thing?
    I asked what collets and what nut, not for smart mouthed comments
    They are proprietary, not an industry-wide standard like ER collets, that is where to buy them from, along with part numbers.
    thanks Got a price for a 3.175mm - 1/8" collet from them today £45 + £5 postage for each size, think a chineese ER11 spindle is the way to go. was hoping that someone may know if there Kress there a lot cheaper, google dose not know before some smart arse chimes in with google is your friend
    Steve
    This listing states the range of spindles which the listed collet will fit -
    http://www.ebay.com/itm/Spring-colle...-/331902104103
    I found this listing in 5 minutes using a little intelligent searching using........
    Yes, you guessed it, Google!
    I was tempted not to bother but it might help someone else later.
    Thanks its helpfull to know there the same, but my spindle is a UFM 500 not listed
    It actually looks like they aren't, the part numbers for the 500 and 1050 collets are different and Kress listing suggests they share a fitting with the 1050, not the 500.
    cheers I have found some kress 580 in germany may just buy one and see, But thank you for trying, I have spent weeks looking for collets and a nut, think im going to put in bottom draw and look into chinese spindle, start reading from scratch again
    Steve
  2. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  3. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  4. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
