    I think the second one. Just give Garry a quick ring at Zapp.
    I already tried that and they didn't seem to know but have emailed tech support at leadshire so hopefully will get an answer Monday as they've all gone home now in China.
    I couldn't see a pinout in the manual otherwise I'd just hack a cable together but the price of the cable from zapp is cheap enough the delivery will be considerably more lol. I have accessed for the pinout if they respond I'll have a goat making my own and post the results ;)
    I gave you the pin out in post #5 simple to make you might have to swap tx and rx around
    I found a cable with the RJ11 connector from an old phone and connected the three wires to a RS232 to USB cable adapter. Worked perfectly.
    I am also used to connect the cable to RJ plugs by hammering the contacts using a small screwdriver shaped to fit the contacts :)
  5. The Following User Says Thank You to paulus.v For This Useful Post:
  6. #4
    Ah I totally missed that thanks!
    Looking at that pin out 6p4c connectors should do it
    http://www.ebay.co.uk/itm/5-x-RJ11-6...x/251168321225
    and just hack the end off an rs232 lead I might even have my old rs232 mouse lol but would be a shame it's from my 486.
  1. Windows 10, is it better than the rest?
    By magicniner in forum Computer Software
    Last Post: 28-11-2019, 11:04 AM
  2. EM806 vs AM882
    By Ger21 in forum Motor Drivers & Controllers
    Last Post: 27-02-2017, 09:57 PM
  3. Replies: 4
    Last Post: 15-08-2016, 03:30 PM
  4. Windows 7 Service Pack 1 Now Available
    Last Post: 01-04-2011, 10:52 PM
