Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
  1. Thank you very much lads for the help, so on the back of the bottom enclosure box I have 3 pins which a kettle like cable plug into:
    This currently is plugged into the power supply box for my controller, can I just taop into these 3 pins and then wire some more wires to the spindle controller l, n and gnd?
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  2. #132
    I imagine that would be fine, can't see it drawing more Amps than that plug is designed for.
    Alex
  3. #133
    Can't see the amp rating for the IEC socket but looks like it should be fine anything over 10amp is in the zone. If it wasn't for some reason you can buy a new higher rated socket very easily on ebay for <£3 but the size of those pins I'm sure that's 10amp minimum.
    A good place to skank these sockets is old PC power supplies for pikeys like me ;)
  4. Again thank you very much lads, will probably have a go at finishing this wiring tomorrow night and report back :-)
    My build blog:
    Chinese 3020t Build
  5. one last question,
    what wires go where from the power supply box to the spindle pcb?
Name:	spindle power cable.jpg
ID:	22987Click image for larger version.
    My build blog:
    Chinese 3020t Build
  6. #136
    What are the two terminals on the left? Power in? If so they will go there from the PSU.
    Alex
  7. #137
    Quote Originally Posted by ravihotwok View Post
    one last question,
    Did you read my post? Or was it not clear?
  8. Will read again mate, took some more pics as well. 1 min
    My build blog:
    Chinese 3020t Build
  9. Ah yes that makes sense except im not sure what wires go from the power pack to the spindle pcb. One main question though, at the moment, the power comes into the planet enclosure from the way via a kettle/pc like plug. It then goes to a switch on the front of the enclosure. It is then wired from the switch to the l, n and gnd of the enclosure power pack. If I link the L, N and gnd from here to the spindle power pack above would these cables handle it do you think or do I need to rewire in a thicker wire?
    I have also wired the cable which goes to the spindle itself wrong, I have now connected this to the terminals which are labelled motor - & +.
    Here is a few pics:
ID:	22994Click image for larger version.
ID:	22995Click image for larger version.
ID:	22996Click image for larger version.
ID:	22997Click image for larger version.
ID:	22998Click image for larger version.
ID:	22999Click image for larger version.
ID:	23000Click image for larger version.
ID:	23001Click image for larger version.
ID:	23002Click image for larger version.
ID:	23003Click image for larger version.
ID:	23004Click image for larger version.
ID:	23005Click image for larger version.
ID:	23006Click image for larger version.
ID:	23007Click image for larger version.
    My build blog:
    Chinese 3020t Build
  10. They say motor - &+ so I think I wired these up wrong, think these are supposed to go to the actual spindle?
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
