    One thing I am curious to know is if you have experienced the Z axis rolling downwards on its own accord -due to the weight- when the stepper is not switched on.
    On my milling machine, the weight of the mill head made it freewheel downwards when the power was off. I remedied this by using a belt drive, as opposed to the direct coupling you have on your Z.
    I assume the the spindle/mount and sliding plate/rails are not heavy enough to overcome the natural thread retention of the ballscrew, so this may not be an issue at all with a router, as I've seen a lot of guys using direct coupling.
    Also, did you go for medium or light preloading for the Hiwin carriages for the Z? I am thinking Medium for the Z, Light for everything else, though I guess it not so important..
    Edward
    Ah my eyes!!! Build porn again!!!
    Quote Originally Posted by JZimmy View Post
    I have been watching your build and I have been amazed by your quality of work. I am starting to design my router and will definitely be taking some ideas away from your build.
    I agree with your comment about increasing the length of the rails but more for the fact that your seals might see some wear the more they run over the edge of the rail unless you have a good lead-in on the rails. I doubt it will be much of an issue here but thought I would point it out.
    Keep plowing away at the build, I enjoy the updates!
    JZ
    Cheers - Yeah I'm not too worried about wear (I can print new seals for a few pennies after all) but I do think there are improvements to be made to this Z-axis design. I was thinking about just making a longer plate with longer rails (and indeed probably will at some point) but I'm actually thinking a v2 will be change enough that it wouldn't be worth modifiying, rather just build an entirely new Z for the v2.
    Quote Originally Posted by Edward View Post
    Edward
    Well, not sure yet on this one. On my X6 it stays put when powered off (and actually requires a fairly good shove to start moving down), so I would expect this one will too - it is a little heavier with the large Z-plate and rails on the moving side, but that will likely be more than offset by the fact i'm using a 4mm pitch screw rather than 5mm like on the X6.
    My carriages are all ZA (medium) preload.
    Nick & Alex - cheers chaps :)
    fifa's Avatar
    Lives in bristol, United Kingdom. Last Activity: 26-11-2017 Has been a member for 8-9 years. Has a total post count of 31. Received thanks 3 times, giving thanks to others 0 times.
    Z axis can be easily blocked with "dummy nut" loaded with spring which is released with electomagnet when the machine (or only Z axis) is on.
    Material for dummy nut is usually nylon or HDPE, therefore no worries for wear.
    Congratulations for CF mill. I am impressed. Professional job.
    regards
    Lovely work there Zeeflyboy. A machine has to function but no harm in making it look nice along the way!
    I've hit a slow spot on my build and other commitments need sorting so looks like you are going to finish well before me. Good progress keep it up.
    Hi Zeeflyboy
    did you calculate? How much did you pay for everything?
    BR//
    Mario
    Sorry, qmarjov - I don't yet have numbers to share for cost. I will do a rough estimate nearer the end though.
    As you guys may have noticed, not much has happened last month or two. What with christmas and work commitments I haven't had time to do anything substantial on the project... The extra work related stuff should abate mid february and that is when I expect to pick this project back up more in earnest, though I may continue to do little bits and bobs along the way.
    The reason for this post is that I just got a cool new toy to play with and thought it was too cool not to share the results.
    When I say "I", I actually bought this for the wife so she could start a little home business to allow her to turn her hobby into a little side income stream. Of course, I get to play with it so I'm just going to count it as one of my toys!
    So what is this new toy? Why a 45w CO2 laser of course!
    We've actually done quite a few little test projects over the last day or two (including some cool stuff like etching slate coasters) to test out the machine and get the wife acquainted with operating it. But today I thought I'd have a little play with the sort of thing I actually want to use it for:
    I tweaked my Logo design and did a quick test in wood to see how it looks:
    Decided it looked nice, so went hunting down some anodised aluminium to try etching.... only thing I had to hand were the thorlabs angle brackets. I popped it and and had a guess at some numbers, came out beautifully! I had to remove the honeycomb tray as the brackets are a little thick to sit on top of that, so that is why the bracket is sat on some chopping boards. This job took about 4 minutes to run through.
    I'm pretty ecstatic with the result there.... definitely opens up some new possibilities in terms of finishing items I make once I've got the anodising rig setup and working.
    Aaaaanyway, back to real life work! Sad times.
  8. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  9. #8
    Nice logo and the laser you bought is a good move for someone who wants to start a home business!
  10. #9
    Well we shall see how it works out, I'm not expecting to be able to retire any time soon but I'm hoping she can make enough money to pay off the expense of the machine/maintenance and generate a little income from something she enjoys doing. Obviously this stuff is becoming more and more accessible so there are a lot of options out there for people looking for bespoke laser created items but I do feel its the sort of low volume thing that fits a "cottage industry" type operation rather well. I think going around and getting some tie-ins with local wedding dress shops and flower shops etc would be a good way of generating some business in a crowded online market.
    But more importantly, I get to play with a frikkin laser!
  11. The Following User Says Thank You to Zeeflyboy For This Useful Post:
There are currently 20 users browsing this thread. (0 members and 20 guests)
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
