    Noticed when cutting small tables, the edges (even with a new bit) are very furry.
    I know a compression bit is the answer but they are expensive and upper cut spirals have worked in the past.
    Is it the quality of the mdf? It seems, the lighter colour it is, the better it cuts (or is that just a coincidence?)
    Stuff from Builders yards, Wickes, B & Q seems to waver wildly in quality. Where do you get decent stuff at good prices?
    Yes, lighter color generally indicates higher quality, often known as super-refined MDF.
    I generally use downcuts.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    a straight flute generally works ok for me certainly better than that
    Quote Originally Posted by charlieuk View Post
    Does it plunge well? Know of any good prices on straight flutes?
    Quote Originally Posted by Straker View Post
    here; https://www.toolstation.com/shop/Pow...traight/p67412
    You should use a spiral lead-in because they are not designed to plunge straight down, I use them all the time.
    Thanks, but isn't that a router bit? I'm talking CNC btw.
    Ha, the router bit has no idea nor cares whether you are using a router or a cnc, in fact I'm suprised you thought there was a difference. (where we are talking about wood products)
    Sorry I thought they were different. I just found a straight fluted mill bit that can plunge (specifically for CNC). Will give one of those a try. Thanks for suggestion. :)
    Plunging is fine but there comes a time when you should look at lead-in moves. What CAM software are you using ?
    I would only be plunging 6mm holes and the start of the table edge. I am using V Carve and Mach 3
  1. NEW MEMBER: Greetings and a question
    By Jono in forum New Member Introductions
    Last Post: 04-04-2017, 12:06 PM
  2. VFD Question
    By Chaz in forum Motor Drivers & Controllers
    Last Post: 14-01-2017, 08:41 PM
  3. PSU question
    By iforeman in forum General Electronics
    Last Post: 23-11-2016, 10:56 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. A question
    By bodgeitandscarper in forum Gantry/Router Machines & Building
    Last Post: 02-12-2009, 08:30 AM
