19-11-2017 #4
Sorry to butt in on your thread but I own a USB CNC3040T and I've tried to get MACH3 to run it but I've never had any success.
In all the videos I've watched, they all use a Parallel cable between the MACH3 PC and the CNC Control Box.
My CNC3040 was sold as a USB CNC but the control box still has a parallel port on the back. I purchased a parallel cable but I could not get Mach3 to work. I went through the setup like all the videos were showing and in the MACH3 settings where you configure your PINS for the Parallel Cable, I only ever got one or two green indicators working and nothing I did would make it work. I couldn't control anything on the CNC using MACH3 so I went back to using the USB CNC software that came with my CNC Machine via USB.
So do you think it would be possible for my machine to run MACH3 via USB? My Control Box for my CNC is labelled as T-D Axis Controller. It is black in color with an angled front panel which has two power switches (Main Power and Spindle) with a rotary pot to control spindle speed and finally a big red emergency stop button - if that description helps.
Inside the control box are the following boards:- JP-382C, JP-1482 and JP-1635
Thanks!
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM -
Looking for parallel port cable
By eurikain in forum Computer HardwareReplies: 3Last Post: 20-02-2016, 01:51 AM -
New machine arrived at port. almost here...
By alboy in forum General DiscussionReplies: 4Last Post: 04-09-2014, 09:40 AM -
new computer with parrelel port?
By kingcreaky in forum Computer HardwareReplies: 10Last Post: 25-04-2014, 06:52 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM
