    I've got myself a uccnc hd bb2 bob that has rj45 connectors. Balazs at uccnc explained that the axis connections are as follows
    HDBB2 RJ45 pin 1. step --- Drive Pul+
    HDBB2 RJ45 pin 2. dir --- Drive Dir+
    HDBB2 RJ45 pin 3. gnd --- Drive Pul-
    HDBB2 RJ45 pin 3. gnd --- Drive Dir-
    I will be wiring to 3 leadshine em705 digital drivers. Would I be correct in assuming that I could link DIR- and PULSE- on the stepper itself ? Or is there a better way to wire the drivers with this BOB ?
    Andrew
    This drive seems to have NPN control signal wiring only and differential. Meaning opposite of what your BOB , common + instead of - , so check further BOB manual, drive manual and ask again if needed. read drive manual and see if that could be changed via jumper or sth. And if not- they are not compatible
    Quote Originally Posted by the great waldo View Post
    Andrew
    Not sure I understand what you mean about linking DIR- and PULSE- on the stepper itself. Unless you have a special stepper with a built-in driver there is no DIR and PULSE on a stepper. Steppers normally only have winding connectors and those are connected to the driver (your Leadshine) motor side, which provides the current and voltage necessary for the motors. DIR and PULSE signals are provided by the motion controller, in my case the UC300ETH, and those signals are connected to a BoB through the DB25 (or other connector types) to drive the opto couplers of the stepper drivers which handles the motors. Do NOT connect the PUL- and the DIR- to the steppers at all, unless you have a special stepper with built in driver.
    The last page shows how to connect the driver.
    Hi A-Camera
    I made a typing error. What I meant to ask can I connect the dir- and the puls - on the stepper driver, as the pin out that Balazs mentioned used one pin on the rj45 socket for both connections. I was wondering if pulse - and dir- are connected together somewhere or they go to ground?
    Regards
    Andrew
    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,971. Received thanks 369 times, giving thanks to others 9 times.
    EM drives have differential inputs, but canbe connected as single ended in NPN or PNP type setups.
    What you want is to connect the drive -'s to gnd, and then the step/dir to the drive +'s.
    And yes, you could connect the drive -'s together at the drive.
    Thanks m_c
    I'm a newbie at all this cnc stuff but am learning by doing (and asking) I'm hoping that the uccnc hdbb2 board is a reasonable one compared to all the other chinese bob's. The uccnc software has been a delight to use. I'm only using the usb uc100 version (contemplating uc300 if it's a worthwhile update) My main use for cnc is woodworking (guitar making) some plastic routing pickguards and maybe a little Ali or brass machining. The manual for the hdbb2 is a bit high tech, I think I need a "trigger" version as opposed to the "del boy" version. Thanks to all on the forum that answer my query's and sorry if sometimes all is not clear 1 o'clock in the morning the brain can be a bit loose after a hard day.
    Andrew
    In the manual of the drive it says only NPN and differential? No words for PNP
    Hi m_c
    I hope i'm not being a pain. Would it be ok to connect the (hdbb2 rj45 pin 3 LPT port ground) to the dir - then a link from there to pulse - ? assuming that the ground would come from the bob. Or would I have to run a connection from the pulse - to the gnd. point on the stepper driver ?
    Thanks in advance.
    Andrew
    Boyan, the EM hardware manual shows all three connection types (NPN, PNP, Differential) - http://leadshine.com/UploadFile/Down/EMhm_P.pdf
    Andrew, for the step/dir signals, you want to stick with the signal ground (i.e. the one from the BOB), and not mix them with any of the power grounds.
    The power grounds should be connected to the signal ground at some point, however you don't want to be using any ground wire that is carrying high currents (i.e. the stepper supply), as it risks problems with interference/noise.
    Sorry, the manual i have downloaded showed only 2 possible connections, which is strange. Good to know. I thought that strange anyway.
  1. UCCNC MyProbe error
    By chipxx in forum CNCdrive (UCCNC)
    Last Post: 22-08-2017, 02:36 PM
  2. Schneider Altivar 320 wiring / setup help needed
    By TadasM in forum Spindles & Drive Motors
    Last Post: 21-10-2016, 07:43 AM
  3. UCCNC and Rodocutter X4 Problems
    By RusticRusty in forum Gantry/Router Machines & Building
    Last Post: 06-06-2015, 09:01 PM
  4. PSU wiring help needed
    Last Post: 25-06-2014, 11:46 AM
  5. Driver wiring advice needed...
    By Wal in forum General Electronics
    Last Post: 09-06-2014, 06:11 PM
