Page 46 of 63 FirstFirst ... 36444546474856 ... LastLast
  1. #451
    I'm going to make a frame from 2*1 on ply wood so the router sits on the frame, then drill a hole in the ply for the vac bed. I can very easily drop the router onto anti vibration mounts or sit it on 20cm thick rubber bump stops.
    Is there any point?
  2. #452
    My wiring is dodgy on the spindle, luckily I didn't damage it!
    I need to resolder properly but I decided today I was in disaster mode and anything I do will break things even more lol. Asked my electrician mate to come help me sort it.
    Tripping out RCD so it's earth related.
    But we did do a test cut ;)Click image for larger version.
  3. #453
    Chaz's Avatar
    Congrats, the first movement is always the sweetest.
  4. The Following User Says Thank You to Chaz For This Useful Post:
  5. #454
    The first movements I had a dead spot on my router where the ballscrew was catching but quickly traced to my motor mounts. Under one of the mounts on one side was a washer but not the other. Removed the washer and all was good ;) Struggling to fit my limit switches lol, broke 3 cobalt drill bits so far bloody M3's far too flimsy.
  6. #455
    So...the first cut is the sweetest!
  7. The Following User Says Thank You to Nickhofen For This Useful Post:
  8. #456
    until the power goes out lol, since it tripped the rcd (doing this cut) I bet it's the earth connection I obviously need to redo it properly.
  9. #457
    Felt brave so I fixed it :) was a dodgy earth
  10. #458
    Nice, I feel your relief...hmmm that didn't sound right!
  11. #459
    You saucy swedes lol.
    I'm going to make this first (As an engraving) to put on the wall next to the machine as no one at work thought I could build this so a nice little F you for them to see daily ;)
  12. #460
    Hahaha :D
    Nick is from greece!
    Love the sign
  13. The Following User Says Thank You to Nr1madman For This Useful Post:
