    Lives in Plymouth, United Kingdom. Last Activity: 5 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I don't know if anyone has done a controlled side-by-side comparison of the AM882 and the EM806. I bought the EM drives for my machine as I was fed up with buying things that seemed to go obsolete almost as soon as they were delivered and the EM series was still fairly new on the street, with supposedly better anti-resonance algorithms, etc. That was around 3 years ago but the AM drives are still going strong! However, I can say that I am very happy with my EM drives - no resonances ever been apparent, and the anti-stall is very useful if for some reason the gantry has gone out of square and loads get too high on rapid feed. Machine stops quickly without tearing itself apart. Would the AM drives have worked as well? Dunno!
    One day I'll make up a serial cable and try to set up the autotune properly. Still slightly confused about how that's supposed to work with a dual-motor setup as you clearly can't do it with the motors connected to the ballscrews, but it doesn't seem to make sense to try to tune the motors when they're unloaded.
  2. The Following User Says Thank You to Neale For This Useful Post:
  2. BUILD LOG: All steel, no welding, 2000x1300x250mm
    By eurikain in forum DIY Router Build Logs
    Last Post: 28-06-2017, 12:51 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  5. Redesign...Steel is now Extrusion
    By FlyHighRC in forum Gantry/Router Machines & Building
    Last Post: 30-10-2015, 10:09 PM
