Thread: New start
    I personally would go down the conventional tried and tested route with a toroidal transformer and rectifier with caps.
    Im leaning towards that route...
    There is no way there could be thats big caps in the drives.. so I guess that if I go ac my toroidal transformer will get a beating? Especially since its a 500VA and not overspeced for my application?
    I considered using AC with my my AM882h's but when one of them blew and I replaced it I got an AM882 which is DC only.
    I might be wrong here but I think if the drive is rated for AC you wouldn't need caps they're only there to smooth out the DC. That said it wasn't hard I was scared of the PSU build and yes I did blow one up ;) but it really was drill a couple of holes, bolt stuff on and solder 6 wires just double check you wiring and don't plug the wires into the rectifier the wrong way round.
    Haha ;)
    Well Im not scared of the process.. but I got a shitload of smaller caps so alot more than 6 solderpoints :D
    Im about halfway through but I cant solder with any kids around.. they just have to touch everything ;)
    I figured since the drives provide the motors with dc then some internal conversion must happen in the drives if using ac supply...?
    Anyway.. it will look cool if I finish so I guess I will stick to the original plan!
    You must go with DC so I can copy the plans and make my DC power supply!
    Lives in Plymouth, United Kingdom. Last Activity: 22 Hours Ago Has a total post count of 1,743. Received thanks 297 times, giving thanks to others 11 times.
    If I had a drive with the option of AC input, I would go with that. It will have an appropriate internal rectifier/capacitor setup, and actually the capacitors do not need to be that big. You use bigger capacitors when the PSU is feeding multiple drives as you are smoothing with a bigger current demand, and it also provides a bit more isolation between drives so demand from one will not affect the others. Stepper drivers really do not need a very smooth supply voltage anyway - because of the way they work, they are pretty tolerant of supply voltage ripple.
  6. The Following User Says Thank You to Neale For This Useful Post:
  1. NEW MEMBER: We all need to start somewhere!
    By Realtime in forum New Member Introductions
    Last Post: 16-05-2017, 08:43 PM
  2. NEW MEMBER: A new start for me.......
    By Nthkentman in forum New Member Introductions
    Last Post: 23-08-2014, 10:50 AM
  3. Where to start?
    By Inquisitor in forum Gantry/Router Machines & Building
    Last Post: 27-11-2012, 02:35 PM
  4. where to start
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 22-09-2012, 11:29 AM
  5. is this 2.5d where do i start? help please if you can
    By h4ppy-chris in forum General Discussion
    Last Post: 29-03-2011, 12:21 PM
