Thread: Emco PC120 Turn
11-03-2017 #81
So I bought one of these and finally tried to install it today. Nothing works. Ive tried every option. The state of P17 doesnt change, even if I press E Stop whatever. It could be that the board is damaged.
Are you able to indicate what the wiring should look like from a board like this please?
http://www.ebay.co.uk/itm/5-Axis-Cnc...item3d32792356
11-03-2017 #82
Sorry Chaz, but I can't get my CNC fired up at the moment. First, you need the relay jumper disconnected and then in Mach3 you need to command the P17 with an output set to pin17 and that output linked to M8 on the Spindle Control screen, so then M8 in your code sets coolant on and M9 turns it off.
You can use any spare axis pulse or direction pin to do the same thing btw, if you want to use the onboard relay for spindle control, which is hard wired into P17 when the jumper is on.
PM me your Mach3 configuration file (you will need to copy it and change the extension to .txt) and |I will have a look at it. I can't remember exactly where we got on this.
Cheers,
Rob
In the meantime I will look at my CNC PC to see why it is not firing up properly !!!! - Have looked at it system SSD is dead, will need to rebuild Operating system and reload software --- S H I T -- !!!!Last edited by cropwell; 11-03-2017 at 04:32 PM.
11-03-2017 #83
Thanks. Ill get the config later (its in the garage).
I tried with the relay setting on and off. I did damage the board however previously when I miswired the on board relay. Cheap enough to replace. I then made Output 3 try both pin 16 and 17 but nothing changes the state of them. Im using output 3 for coolant and triggering it doesnt change anything. Perhaps I need another board first. Id love to go CS Labs as its something I understand but too pricy for a machine ill likely be selling.
As I think that the inputs are powered from the 12-24v supply (don't quote me though)..Clive
11-03-2017 #85
I am sure you are right Clive, the 5v from the PC is only to power the input optos. I have the board in front of me and the 12v track is on the top face and disappears under components, so I can't trace it through.
(Chaz) The board you show as an example on eBay is overpriced, you can get them from China for less than a fiver and not much more than that from a UK supplier.
RobLast edited by cropwell; 11-03-2017 at 06:36 PM.
the PC is only to power the input optos..Clive
11-03-2017 #87
11-03-2017 #88
Probably, but I am sure they do more than just provide clarity
I am up to my neck in computer problems at the moment. The computer says press any key to boot from CD.... and I can't find the 'ANY' key - none of the ones on the wireless USB keyboard work and I haven't got any other sort.
11-03-2017 #89
11-03-2017 #90
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Denford Star Turn 3
By MarkBrown in forum Workshop & EquipmentReplies: 2Last Post: 02-12-2014, 10:57 PM -
Getting the stepper to turn
By thorphar in forum General ElectronicsReplies: 0Last Post: 16-09-2014, 07:48 PM -
11 hours of trying to get the motors to turn, help please
By Wotsit in forum Stepper & Servo MotorsReplies: 19Last Post: 05-02-2013, 03:07 AM -
LED not turn on
By Awel in forum Motor Drivers & ControllersReplies: 1Last Post: 06-12-2011, 06:59 AM
