Thread: Bench-top or welded frame
25-02-2018 #13
Well I'm surprised at that.? Thought you'd been around long enough to know better than that.! . . . . Design first then buy later is golden rule.
Yes that's the idea thou wouldn't fasten between those two gantry uprights as it will make setting up difficult with little room for error.
Fasten rails on front, ballscrews on side and put brace between gantry uprights at top. Connect two ballscrews with belt and single motor running along top of brace.
Put rails on front of gantry and ballscrew on top.
BUILD LOG: Desktop size steel welded router 3 axis
By Tom J in forum DIY Router Build LogsReplies: 84Last Post: 28-03-2017, 09:36 PM -
building with steel tubing pre-welded plates with holes doable?
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 14-09-2016, 03:26 PM -
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Bench Top Mill
By Wobblybootie in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 04-06-2010, 06:57 AM
