    I have an XSY-AT1 inverter 3pH, i'm setting it up for the spindle below and just have a bit of a problem with the terminology in my manual, which differs from much of the documentation I see about the HuanYang, which I was using as a reference.
    I'm just trying to get the basics set up, 400khz and min freq 120khz etc. What are the following setting I should input for the perameters below?
    P00 Max voltage
    P01 Reference voltage
    P02 Intermediate voltage
    P03 Intermediate frequency
    P04 Min voltage
    P05 Min Frequency
    P06 Max operating
    P07 Min operating
    2.2kw air cooled spindle
    current 220v
    Current 6a
    Frequency 400htz
    speed 10-24000htz
    2 pole
    I'll never understand why people keep buying these chinese VFD's that noone's ever heard of, and then ask how to set them up???
    Did it come with a manual?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I suspect the reason is that, like many people, They're Cheap! :D
    But they're not any cheaper than a Huanyang, and in many cases, people pay more for them.
    Gerry
    I've stuck with the big 1st world names with brilliant documentation for 20 years, as I put a positive value on my time I figure I'm well ahead of the game ;-)
    Apologies for the silence been in the Cairngorms!
    I bought it because its dimensional height meant it would fit in my control box. It has a manual (of sorts) Here’s a scanned page with some of the key perameters to set.
    If the Huanyang would fit in my control box I would have bought one. Click image for larger version.
Name:	manual Scan1.jpg
    From the looks of that you need to set
    Maximum Operating to 400 and
    Minimum Operating to the correct percentage of 400 to give your spindle's rated minimum speed.
    Reference Speed to 400 and
    Intermediate Speed to halfway between 400 and minimum rated speed
  8. The Following User Says Thank You to magicniner For This Useful Post:
  9. #8
    thanks thats very useful information.
  10. #9
    I have virtually the same setup as you but just cant get the spindle to run with any consistency. The spindle starts and slowly builds up speed but stutters and then trips out on Err 1 (Short circuit/Current overload/Power module protection). I have tried numerous combination of settings to no success. I assume you have your system running and would be grateful if you or others can point me in the right direction.
  11. #10
    Quote Originally Posted by shortcircuit48 View Post
    Sounds familiar . I'm not near the cnc till tomorrow but can paste the P1-P8 VFD settings, which might be of use.
  1. Boxford 260VMC with toolchanger Lenze spindle speed issue/query
    By swood1 in forum Boxford Vertical Mills
    Last Post: 27-03-2018, 03:18 PM
  2. Water cooled vs Air cooled spindle for wood
    By Bucks in forum Machine Discussion
    Last Post: 06-02-2017, 01:58 PM
  3. Where to buy 2.2Kw Water cooled spindle + VFD
    By RocketBoy in forum Marketplace Discussion
    Last Post: 01-08-2016, 12:38 PM
  4. Water cooled / air cooled 2.2kw spindle
    By suesi34e in forum Generic Chinese Spindles
    Last Post: 25-02-2015, 04:57 PM
