Page 2 of 2 FirstFirst 12
    I've always been a big fan of MeshCAM since the first beta.
    However, a few years ago, the developer formed Carbide 3D, and since then, development of MeshCAM has slowed to a crawl.
    But it is still being developed. The current version of MeshCAM 7 was released about 4 months ago. But in it's current state, I prefer version 6.
    If I ever get a machine running with a rotary axis, I'll probably invest in a copy of DeskProto.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Is Deskproto mainly for rotary axis. I am only using a flat bed CNC.
    Simon
    No, but it has a lot more rotary axis features than anything else.
    Gerry
    Lives in Plymouth, United Kingdom. Last Activity: 16 Hours Ago Has a total post count of 1,748. Received thanks 298 times, giving thanks to others 11 times.
    I'm not quite sure if you want to convert your STL files to a 3D CAD format, so that your machine operator can then run it through his favourite CAM package, or whether you want to do the CAM yourself. I have used Fusion 360 to do the latter (and it's free if you are a student). Converting to a standard 3D file format is always going to be a little more difficult as it's not really a logical thing to do in most cases as straight to CAM/gcode makes more sense - but you need to know machine parameters like cutting speeds, cutter sizes, etc, to do it properly.
  5. #15
    How would MesCAM/Deskproto compare with BobCAD? Especially the new version.
    I had a look at the previous version of BobCAD and found it looked rather complicated. Can it do more than the other 2?
    Zymon
  6. #16
    Run away from BobCAD as fast as you can, and don't look back.
    Gerry
  1. Free CNC Vector Art Design & Pattern Files (DXF Files)
    By tanvon in forum CAD & CAM Software
    Last Post: 21-06-2018, 10:17 AM
  2. anybody got any 3d stl files they can send me
    By kingcreaky in forum General Computing
    Last Post: 20-11-2013, 06:16 PM
  3. 400 megs of files in dxf
    By Anónio Pinho in forum Computer Software
    Last Post: 18-05-2012, 11:01 PM
  4. help needed for .drg files
    By swinds in forum Machine Discussion
    Last Post: 22-06-2011, 09:18 PM
  5. Help with X3 mill and XML files
    By Eugene in forum Milling Machines, Builds & Conversions
    Last Post: 12-03-2011, 01:01 PM
