31-08-2018 #2
02-09-2018 #3
Cropwell and Magicniner.
Many thanks for taking the time to respond to my reach for help. I will post photos of the insides of the controller. I hope to find a blown fuse. I suspect that would be too easy tho!!!! (Identifying fused circuits on the BoB relay may be interesting!!!)
Many thanks for the steer to Bionica. That looks like they there buggars!!
03-03-2021 #4
Hi Peter,
Sorry to hear all the problems you are going through, but I am on the same boat, I have a A1 Marchant Dice CNC router and full package bought from them on 2012, and up to today I haven't been able to used it, due to a problem with the reset botton that I found when I first plug it in, so now I am trying againg, and I have opend everything to see if there is anything blown, breaking fuse, by the way there are at least 3 fuse to check as you ask before, but I have install mach3 as they said, all light on the controll box are green, but I don't know the set up of mach 3, as what they send to me is not really working.
¿Could you or any other user send me your set up of mach3? by the way I have 4th axis, but I haven`t install the 4th axis yet.
King regards,
Braulio
26-04-2021 #5
But the most important thing, is to check the Max Amps that your step motor can take, so you don't buy extra ppower supply thinking that you need them when you really can take the maximun of your dirvers.
05-07-2021 #6
Hola Raul,
Buenos dÃ*as, espero que todo vaya bien .
Veo que está dedicadose en la máquina de CNC, si tú o tus amigos necesitan hacer las partes por CNC máquina ,es mi placer de ayudar la cotización.
Mi fábrica lo hacemos y también de las partes de plásticos, lo siento mucho por molestar, si no hace falta, solo saludar de China.
Julia Lian
[email protected]
+86 185 592 13117 wechat / whatsapp
BUILD LOG: A3 Marchant Dice Kit
By neo in forum DIY Router Build LogsReplies: 25Last Post: 03-03-2021, 11:54 AM -
Marchant Dice
By agent17 in forum Marketplace DiscussionReplies: 28Last Post: 06-06-2020, 11:06 AM -
CNC-Step High-Z S-400 or Marchant Dice MDL-2-TR ?
By No1_sonuk in forum Marchant Dice MachinesReplies: 10Last Post: 20-04-2009, 12:39 PM -
Marchant Dice on eBay
By irving2008 in forum Marketplace DiscussionReplies: 4Last Post: 06-09-2008, 05:37 PM
