    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by joss01 View Post
    It has a polish made controller PIKO that has a dedicated software. http://www.pikocnc.com/download-1
    The cnc is a Polish built machine is CREBER very well engineered. But I need to to set it up correctly and I have no experience in this field.
    This video shows the cnc being built https://www.youtube.com/watch?v=bxGE0l1MUlo
    I have been told to change the controller and software all together but I still need someone to set it up.
    Thanks for getting back hope to here from you
    Regards
    Joss
    Ah, I think you posted before, I remember the machine and the vid. Are you looking for someone to fix the current control setup or potentially retrofit it / modernise it?
    Hi yes that was the post.
    The cnc 3 years old and very well made it has a 1 x 2 meter bed 200mm gantry height, it is 440volt, it will soon have pneumatic material clamps fitted and has a tool bit chiller fitted. It is primarily use to engrave memorials, relief work in stone and war memorial plaques. The machine is used frequently used and operates well. My issue starts here the cnc was built in Poland with PIKO operating software which there is no English software available so operating the cnc has been a learning curve. I want to upgrade the control unit to and software to Masso unit or something similar and I am looking for someone to carry out the upgrade.
    Thanks for responding
    Chaz's Avatar
    If its running something proprietary, why not move to something like Acorn centroid or does the current control system do a lot of the CAD / CAM for you? How do you current generate G Code or is this done by this unit?
    The controller is connected via a USB to the pc. I generate the designs via Aspire V carve save it then open the file in the proprietery software designed by PIKO. I have not attempted to try a generic controller software but I don't think it will work. So to answer you question yes it does do the CAD/CAM.
    Yes and I am still looking for someone
    Hello Boyan thank you for that piece of advice I had no intensions of installing Mach 3 as I have read some negative reviews. As far as staring up is concerned I control the XY axis to suit each piece of work via the controller.
    I am looking for someone to modernise /upgrade the controller but I am not having much luck finding somebody who can come back with a straight answer
  1. Replies: 0
    Last Post: 25-01-2016, 11:46 AM
  2. CNC Maintenance Technician Job Opportunity - SeaStar Solutions, Richmond, BC, Canada
    By Etranhirose in forum Opportunities Available & Sought
    Last Post: 10-09-2015, 12:35 AM
  3. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
  4. NEW MEMBER: Technician, secondary education
    By Nic in forum New Member Introductions
    Last Post: 22-07-2011, 12:34 PM
  5. Maintenance Technician/Engineer
    By mvolt in forum Opportunities Available & Sought
    Last Post: 16-02-2011, 10:38 AM
