Thread: Work scrap bin router build
Hi
I get confused with the axis terminology, but I did mean that the Y is longest.
I havent got the model to hand at the moment (at work) but I think the bearings are about 270mm centres I'd like to keep it around 4ft cutting area and don't really want to make them wider if I can get away with it.
I'm not certain what you mean about controlling the racking with belts or wire ? do you have any links to something that has used something like that ?
The design started off using box section, I am aware that I might get some flex with channel, I have some ideas about strengthening it if I need to, the problem with box section is bolting the steel angle to it, you cant get to the nuts to tighten them up, I thought about using large self tappers but I think they might vibrate loose so I went for channel, it's a pretty strong channnel as it's meant for supporting the floors of trucks but your right, it will twist more than box.
Vic
11-01-2010 #2
Think back to those old cars with box section chassis, how did they get round the problem? SImply drill/bore out a hole in the box opposite the nut so a long socket or socket+extension can be passed through the hole withthe nut held in the socket with a dab of grease.. If the rear of the box isnt accessible then cut a slot in the wall of the box sufficient to get a spanner and nut through. Third option is to create captive nuts by drilling/tapping out a piece of steel that is a sliding fit in the box section (only really works for narrow section). A fourth option, if the wall of the box section is thick enough, is to tap it directly. And a fifth option is to cut a rectanglular slot where the hole should be, slide in a tapped piece slightly narrower but longer than the hole and weld in place.
11-01-2010 #3
He means like this
BUILD LOG: Melbourne Andy CNC build 1220x810 work area
By AndyGuid in forum DIY Router Build LogsReplies: 4Last Post: 20-04-2014, 08:25 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
Recycle electronics or scrap?
By gavztheouch in forum General ElectronicsReplies: 2Last Post: 05-02-2014, 04:16 PM -
eBay: Optical PCB drill - save it from scrap someone!
By bikepete in forum Items On eBay UKReplies: 1Last Post: 14-11-2013, 11:42 PM -
BUILD LOG: Scrap Heap Challenge
By TrickyCNC in forum DIY Router Build LogsReplies: 38Last Post: 16-09-2012, 07:52 AM
