    Lots of consideration to take into account.
    My machine worked well with the original motors, (it was fully functional on 3 phase when purchased). As previously mentioned, I was also very conscious of electrical max demand of finished machine, as well as keeping running costs reasonable.
    The 1.5KW version might have been a choice otherwise, as you could just pull the rotors out of the motors and machine the shaft ends down.
    Or fit different pulleys, as mine are tapered collet type. Having said that, I could probably bore out originals and broach a key way in to fit those 19mm shafts. Extra length makes no difference on Z or Y on my Interact. Your MDI has a longer X axis cover for the manual handles, so it may make no issues there either.
    Only things that may catch you out is the rotor inertia and the possible effect of having so much Torque. ( although you might find a 4NM version in 110ST.
    I partly figured that if my 90st 4NM versions ended up being too small in the end, I could always use them on the next project ( cnc lathe).
    Guess its all a gamble really. The only good thing ( in my view) is that as they are 220V AC, there is no need for huge power supplies and torriods. Time will tell
    Mark.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by swarf-boy View Post
    Mark.
    Thanks. Good points. Torque can be limited. I'd rather have too little than too much - that said, is rotor inertia a real concern?
    Thheir 0.8 KW is 2K RPM, the 1.2 has the same rotor inertia. The next one down is 0.6 KW, so too small in this frame size.
    Chaz's Avatar
    In the end I was able to get some Panasonic stock from the supplier of my previous kit used on my other mill (Thor)
    I will have 2 x 0.75KW and 1 x 1.0KW available. Ill likely install the 1.0KW setup on Thor and then have the same three for the Bridgeport.
    Chaz's Avatar
    Managed to get two of these 800 x 600 x 300 enclosures for fairly cheap. Perfect for this (I was thinking to use the original box), but this will work too.
    Testing a layout. Any thoughts / concerns with what I am proposing? The VFD will be placed externally.
Name:	WhatsApp Image 2019-01-25 at 16.43.59.jpg
Name:	WhatsApp Image 2019-01-25 at 15.56.32.jpeg
    Nice project Chaz.
    I’m sure you know this stuff but when I did my box I followed a few guidelines and have not had any problems or false estops:
    Power lines separate from logic lines
    24V logic wherever possible (not 5V)
    Star Earth point
    Drivers in a row not column so heat went up and away
    VFD tucked up in the top left corner so air came in through the left side of the panel and straight out the top (if your VFD fan draws from the left side)
    DIN rail power supply not the generic ebay power supply (just for ease of mounting, not sure if there is any electrical principle difference)
    Ferrules on each cable
    Final tip is give your fingers room to get in to insert cables and space for the screwdriver.
  6. The Following 2 Users Say Thank You to routercnc For This Useful Post:
  7. #6
    Chaz's Avatar
    Making progress, wired up most of the controls, quick test run with some existing / included code. Axis are not calibration yet (distance etc), wanted to check movement. It sounds like the X belt is fouling, will need to sort.
Name:	WhatsApp Image 2019-01-27 at 13.45.03.jpg
Name:	WhatsApp Image 2019-01-27 at 14.20.30.jpg
  1. Bridgeport Series 1 Interact. Refit/update . Opinions please.
    By swarf-boy in forum Bridgeport Milling Machines
    Last Post: 03-11-2024, 02:56 AM
  2. NEMA34 motor selection for Bridgeport Series 1 CNC
    By heb-cnc in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2018, 10:29 PM
  3. Longs 3 axis CNC kits - are they suitable for Bridgeport Series 1 conversion?
    Last Post: 04-11-2018, 12:19 PM
  4. eBay: Bridgeport J Series Turret Mill
    By steve400 in forum Items On eBay UK
    Last Post: 24-04-2017, 04:11 PM
  5. Bridgeport series 1 MDI / CNC tooling
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2013, 04:47 PM
