    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    DMM sales are always very quick to respond.
    Their tech support, not so quick. There have a been a couple guys using KFlops that have had issues. One just couldn't get a drive to tune in analogue mode until he fitted their suggested mains filter, yet all the other drives were fine without the filter, and the issue moved with the drive, not the wiring.
    Somebody else blew a drive up within seconds of turning it on, which was apparently due to being over-voltage, and due to them not fitting the recommended mains filter they wouldn't warranty it, yet the other drives never failed.
    Plus they use capacitive encoders.
    Their big advantage as you've discovered is they've specced the motors so they're far more likely to be a drop in replacement for old stepper motor systems.
    Personally if cost was the main concern, I'd opt for cheap Chinese.
    What tooth profile are the pulleys?
    The pulleys are 12 (X and Y) and 13 (Z) respectively. H pitch. Beltingonline are telling me they can have them made to order but warned that they will be pricy (I need to send them some pics) as I've suggested that maybe I just bore them out and install a grubscrew.
    In terms of costs, sure, I dont want to spend more money than I need but I could get this machine running on steppers for a lot less money, that's not the point here.
    If the DMM stuff isnt much better or doesnt offer more than perhaps an easier fitment, then I might as well save the money and use that for a better touchscreen / PC whatever. I'm not trying to cheap out on the build but dont see value in paying for something that doesnt offer better. Of course the law of diminishing returns persists too.
    As an example I have Panasonic drives and motors on Thor and cheaper Chinese stuff on my old Triac. The Triac worked OK but no doubt the Panasonic stuff is better. The only reason I bought them was that I got some stuff at good prices from an Ebay seller. I wont pay RRP or similar for Panasonic.
    I can get away with a 750W system, been avoiding it due to mounting concerns, bracketry might be OK, motor shaft diameter and length are the main concerns. One guy on Youtube has basically extended his motor shafts to suit.
  2. I bought some bar stock and made them myself. not that hard.
    Or modify the existing pulleys to fit on the new motors.
    Just been checking out your acorn control.
    Interesting unit. Quite a lot in the Kit.
    Options seem to get strangely pricey though
    ( $45 for a dual circuit E-stop, being a stand out).
    See those 4 series drives look to have built in S curve feature.
    Didn't know that was a feature in drives. ( every day is a school day, as they say).
    Chaz's Avatar
    Quote Originally Posted by Gary View Post
    Thanks Gary.
  5. #15
    Chaz's Avatar
    Quote Originally Posted by swarf-boy View Post
    Yep, mine was ordered on Wednesday, import tax is a bit harsh, might be delivered today or Monday latest.
    I have some potential Panasonic servo motors sorted, will check over the weekend and see if they will work then i need to sort out mounting / pulleys.
  6. #16
    Chaz's Avatar
    I'm trying to decide what motor to go for.
    80 Size - 19mm shaft but 35mm long.
    90 Size - 16mm shaft, same length.
    Both those have near identical specs.
    110 Size is almost a direct replacement but the shaft is 19mm and longer which is I think is ideal. This is for a 1.5 KW setup, around $100 per setup more expensive (not much of a concern).
    Which would you go for?
  7. #17
    Lots of consideration to take into account.
    My machine worked well with the original motors, (it was fully functional on 3 phase when purchased). As previously mentioned, I was also very conscious of electrical max demand of finished machine, as well as keeping running costs reasonable.
    The 1.5KW version might have been a choice otherwise, as you could just pull the rotors out of the motors and machine the shaft ends down.
    Or fit different pulleys, as mine are tapered collet type. Having said that, I could probably bore out originals and broach a key way in to fit those 19mm shafts. Extra length makes no difference on Z or Y on my Interact. Your MDI has a longer X axis cover for the manual handles, so it may make no issues there either.
    Only things that may catch you out is the rotor inertia and the possible effect of having so much Torque. ( although you might find a 4NM version in 110ST.
    I partly figured that if my 90st 4NM versions ended up being too small in the end, I could always use them on the next project ( cnc lathe).
    Guess its all a gamble really. The only good thing ( in my view) is that as they are 220V AC, there is no need for huge power supplies and torriods. Time will tell
    Mark.
  8. #18
    Chaz's Avatar
    Mark.
    Thanks. Good points. Torque can be limited. I'd rather have too little than too much - that said, is rotor inertia a real concern?
    Thheir 0.8 KW is 2K RPM, the 1.2 has the same rotor inertia. The next one down is 0.6 KW, so too small in this frame size.
  9. #19
    Chaz's Avatar
    In the end I was able to get some Panasonic stock from the supplier of my previous kit used on my other mill (Thor)
    I will have 2 x 0.75KW and 1 x 1.0KW available. Ill likely install the 1.0KW setup on Thor and then have the same three for the Bridgeport.
  10. #20
    Chaz's Avatar
    Managed to get two of these 800 x 600 x 300 enclosures for fairly cheap. Perfect for this (I was thinking to use the original box), but this will work too.
    Testing a layout. Any thoughts / concerns with what I am proposing? The VFD will be placed externally.
Name:	WhatsApp Image 2019-01-25 at 16.43.59.jpg
Name:	WhatsApp Image 2019-01-25 at 15.56.32.jpeg
  1. Bridgeport Series 1 Interact. Refit/update . Opinions please.
    By swarf-boy in forum Bridgeport Milling Machines
    Last Post: 03-11-2024, 02:56 AM
  2. NEMA34 motor selection for Bridgeport Series 1 CNC
    By heb-cnc in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2018, 10:29 PM
  3. Longs 3 axis CNC kits - are they suitable for Bridgeport Series 1 conversion?
    Last Post: 04-11-2018, 12:19 PM
  4. eBay: Bridgeport J Series Turret Mill
    By steve400 in forum Items On eBay UK
    Last Post: 24-04-2017, 04:11 PM
  5. Bridgeport series 1 MDI / CNC tooling
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2013, 04:47 PM
