Page 2 of 2 FirstFirst 12
    I think the inserts were just mild steel, not even HSS or something. Or they tried to bind the tungsten carbide particles with super glue? :)
    A lot of the cheap tools are sintered Tungsten carbide and they don't have the strength to hold an edge.
    Quote Originally Posted by feldah View Post
    Oh thanks. I just saw the Chinese ones. How long do these Arden bits stay sharp. As the expensive ones have exchangeable blades.
    I don't know how long will they stay sharp. I didn't used them a lot and are all still sharp. I used the most a 1' dia round nose bit cutting about 500-700 meters in MDF and it is still very sharp.
    I was also looking at CMT tools with replaceable inserts but I think the price is justified only if you are routing MDF as a business, which would mean cutting maybe 500 mtr per day or hour.
    I think all tungsten carbide in tools is sintered. Mixed with cobalt and liquid sintered, where the cobalt melts and fills the space between the carbide particles. Most likely those Chinese inserts had no tungsten carbide in the composition, they looked more like cast iron, maybe had some iron carbide inside :)
  3. The Following User Says Thank You to paulus.v For This Useful Post:
  4. #13
    That's fair enough. If I can do my spoilboard once with it I am happy. I think one time will be all ready 200 - 300 m.
    What cutting depth do you do? More than 1mm in one run?
    Sent from my MI 6X using Tapatalk
  5. #14
    My spoilboard is actually my router table. I never cut through it. I am surfacing it only every few months with a depth of a few tenths of a millimeter. How have you got 300 m cut for the spoilboard surfacing? My table is 1400x1000 mm, with my 2" dia tool I take 50 mm width of cut which means 20 cuts of 1.4 m = 28 m.
    As MDF is abrasive it is important to have the chipload as high as possible. It depends on the stiffness of your router, the tool dia & length, depth of cut and desired cut finish.
    For example, let's say you are cutting with 24k rpm and 1000 mm/min feed and I do it at 8k rpm and 4000 mm/min with the same cutter. So for the chip thickness that I am cutting you make 12 cuts, your tool will wear 12 times faster.
    You want to get out of the cut chips or shavings not dust.
    Here is an example:
    And here is rounding with an Arden "point cutting roundover" bit (for straight cutting I'm using the popular Chinese 6 mm dia single flute carbide bits):
  6. The Following User Says Thank You to paulus.v For This Useful Post:
  7. #15
    Great explanation. Sadly I won't have prior information about the stiffness. But I know that I will use a 2.2kw Spindle which can handle 1/2" shanks.
    My 300m comes because my table is 4 times longer(1,2m - 1m) x 4m. Because it is my first cnc I am building. I was expecting an uneven table with 3mm height difference. But that's just a guessed number. So with a 2" tool and 1mm cut depth I assumed 20 x 4m x 3 rounds -> 240m. But as you said you are going a few tenth of a milimeter it will even be more runs.
  8. #16
    I'm taking a few tenths of a millimeter to clean the table from time to time. You may be able to go 3 mm depth in one pass but it depends on the stiffness of the machine.
  9. The Following User Says Thank You to paulus.v For This Useful Post:
  1. best router bits ?
    By totally useless in forum General Discussion
    Last Post: 01-05-2015, 11:53 AM
  2. Router bits for use with Slate
    By habibuzziwa in forum Tool & Tooling Technology
    Last Post: 30-06-2013, 06:12 PM
  3. 3.175mm router bits
    By ian stenson in forum Tool & Tooling Technology
    Last Post: 13-06-2013, 07:59 AM
  4. SWAP: 6mm Carbide CNC Router Bits for 3mm's
    By Fivetide in forum Items For Swap
    Last Post: 04-12-2012, 04:47 PM
  5. CNC Router Bits
    By ploughex in forum Milling Machines, Builds & Conversions
    Last Post: 01-08-2010, 06:26 PM
