    Hi guys I have a TB6600 rated at 4 amp and a 4 wire Nema 23 rated at 4.2 amps if I wire up the controller to the motor will it burn it out or do some damage ?
    I could buy a TB6600HG which is rated at 5 amp just to be safe
    Ralph Waldo Emerson
    If you use a TB6600 stepper driver set to 4A
    a stepper motor rated at 4.2 amps will run at the 4A set by the driver so there should be no problem
    the motor torque will be reduced to 4/4.2 of the rated torque
    having said that I would be inclined to use the TB6600HG so the stepper driver is not run at is limit
    John
  3. The Following User Says Thank You to john swift For This Useful Post:
    Thanks for the advice John I think Ill go with the 5 amp controller as you said.
    Ralph Waldo Emerson
  5. #4
    Quote Originally Posted by Fivetide View Post
    Have you taken in account of the voltage to the drives?
  6. #5
    Hi Clive - I sort of guessed it as I'm no expert but I have a PSU rated at +24v @ 14.6 amp . At the moment I haven't tried just using the 3rd 178 oz Nema 23 it may be ok on the live jobs I 'm going to be doing. and the only difference in fixings is coupling size. The larger 23 I haven't purchased yet but is intended to spin the lathe chuck - in the event 178 needs some more torque at higher feed rates mainly for finishing cuts, although it may be way over the top. The lathe is basically a motorized wood copy lathe, I'm not machining anything that's precise, but if i can get a decent rpm and make a finishing cut of 1 to 0.5 mm without jamming - then it will have done the job intended. :)
    First I'm going with a direct drive attempt as its very simple to set up. I also have a 1:2 pulley system I could try if that fails. And if that wont work I'll go for the 425oz.
    1. x1
    Manufacturer Part Number 23HS45-4204S
    Step Angle 1.8°
    Holding Torque 3.0Nm(425oz.in)
    Rated Current/phase 4.2A
    Phase Resistance 0.9ohms
    Recommended Voltage 24-48V
    Inductance 3.8mH±20%(1KHz)
    Weight 1.8kg
    2. x3
    NEMA 23 MOTOR SPECIFICATIONS:
    Holding Torque: 178 oz/inch
    Mount : 56.4mm x 56.4mm
    Shaft diameter: 6.35mm (1/4inch)
    Rated current: 2.8A DC
    Recommended Power Supply : 24-48VDC
    Step angle: 1.8 degree
    Ralph Waldo Emerson
  7. #6
    I suppose what I am saying is 24V might be a bit low to do what you are thinking of but the limitation of the drives you have will dictate the max voltage.
  8. #7
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    For a lather spindle, a stepper really isn't good. The torque will drop of far too fast, and I'd think you'll struggle to get even those shallow depths of cuts.
    For cheapness I'd suggest finding a suitable basic DC motor, and combine it with a basic speed controller. Gear it with a suitable poly belt to get spindle speed within a suitable range, and you'll have a far more capable spindle.
  9. #8
    m_c what about a high-bred I believe they are much better at high rpm in keeping good torque? My mate has the original motor in bits he seems to think it can be salvaged, it may become a combination of DC and stepper motor like you say with a PWM. I want the flexibility of simple spindle work and carving, its all theoretical at the moment until I get it full assembled and tested - I'll let you know the results :)
    Ralph Waldo Emerson
  10. #9
    It depends what you mean by hybrid. Pretty much all stepper motors you buy now are technically hybrid motors (most square motors are hybrid), and they are far better than conventional (typically round) stepper motors.
    A quick search of eBay has thrown up the likes of this - https://www.ebay.co.uk/itm/200W-220V...e/253850778051
    And they also sell a 500W version with a basic speed controller - https://www.ebay.co.uk/itm/500W-220V...d/253982275690
    To give you some reference figures, using the speed torque curve of a leadshine nema 23 motor (http://leadshine.com/productdetail.a...S&model=57HS22 - one of the first motors I found that has the needed data), at 2000RPM depending on configuration/supply voltage it's only producing 0.4 to 0.7Nm, which works out at 80 to 150W of mechanical power. To get that relies on driving the motor at 68VDC. Drop the voltage, and the torque will drop of far quicker.
    At that point costs are verging in to the same as buying a small single phase motor, or even three phase and cheap VFD. A quick ebay search shows a 1/2HP 3 phase motor can be had for £62, and a suitable VFD for £45. It will likely cost you more than that to get a suitable 68VDC power supply and suitable stepper drive.
    The only thing with using a standard induction motor, is they are far larger than a similar power DC motor.
  11. The Following User Says Thank You to m_c For This Useful Post:
  12. #10
    m_c I ment closed loop stepper sorry
    - Closed-loop vector control technology ensures the high torque output, while ensuring that the motor does not lose step.
    - With overvoltage, overcurrent, tracking error or over-error, and other protection features.
    - Closed-loop driver can significantly improve the high-speed performance of the motor, increasing the effective torque of the motor by more than 30%; Effectively reduce the motor heating and motor vibration, the output current of the driver becomes larger or smaller as the load and speed increase or decrease; It can improve the processing speed and accuracy of the machine and reduce the energy consumption of the machine.
    Ralph Waldo Emerson
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. No longer lurking, stepper motor question.
    By simonparkes in forum Stepper & Servo Motors
    Last Post: 26-03-2014, 11:52 AM
  3. Replies: 1
  4. Stepper Motor Power Question
    By boldford in forum Gantry/Router Machines & Building
    Last Post: 17-07-2012, 09:40 AM
  5. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
