    How much accuracy do you need on the final machine? Somewhere between 0.01 - 0.05 for general hobby might be OK and was the range I was aiming for on my latest machine.
    If you look at my YouTube video around episode 16 you can see my experiences using epoxy to level rails directly (channel is routercnc)
    I found it set level to at least 0.05 mm and probably more but I couldn’t be sure as my reference surface is not a proper calibrated one. Just be aware of the problem with bubbles and ways to get rid of them.
    If you want to level rails you can also use shims and an engineers precision level. The 300mm square level was around £100 but measures down to 0.02mm over 1000 mm. I must have paid ~£80 for 2 sets of epoxy mix so actually the level is good value as it can be reused !
    Yes your opinion sounds reasonable. I didn't have a specific precision in mind. I just like to know what options there are. My idea with the epoxy was to pour it on a piece of metal or maybe even granite. And use that as a reusable reference. I think I get the Westcoast Epoxy for around 20$. I also have a vacuum chamber to get rid of the bubbles. It would be a nice try. But without a super precision reference I will never know if it worked :-)
    Sent from my MI 6X using Tapatalk
  1. DIY straight edge with Epoxy+ aluminum profile. Will it work?
    By ba99297 in forum Tool & Tooling Technology
    Last Post: 19-10-2019, 09:54 PM
  2. A4 Reference Chart Storage
    By magicniner in forum Workshop & Equipment
    Last Post: 29-06-2016, 05:54 PM
  3. Establisihing reference for rail alignment
    By tropostudio in forum Gantry/Router Machines & Building
    Last Post: 14-05-2015, 08:28 PM
  4. can't cut straight or even drill straight, so need help
    By deannos in forum Machine Discussion
    Last Post: 02-10-2011, 05:35 PM
  5. Schematic Symbol Reference
    Last Post: 23-01-2008, 03:23 PM
