Thread: Plumbing a water-cooled spindle.
Here matey. have a look at this - https://en.wikipedia.org/wiki/Antifreeze
21-05-2019 #2An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
21-05-2019 #3
21-05-2019 #4
Well it used to be green! That's only the fluorescein dye anyway. I Think the last time I actually bought anti-freeze in a shop Mrs Thatcher was still PM. I'd had enough of grovelling about under cars at the side of the road by then and vowed that as soon as I could afford it I was going to pay someone else to service my car. I would, of course, now purchase the latest safety approved product from a reputable Australian supplier.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
21-05-2019 #5
Any good quality Ethylene Glycol based anti-freeze has corrosion inhibitors which will work well in a system which includes Iron, Steel, Aluminium, and/or Brass, use De-Ionised water too to avoid any chance of impurities building up inside the spindle.
22-05-2019 #6
I'm afraid Ethylene Glycol is out due the risk of poisoning the dogs if I get a leak and they lick it up. I'm tempted but my wife would never forgive me! The Proylene Glycol version is OK so I'm going to head for our local Auto-Pro and read the labels very carefully.
I obviously don't need the anti-freeze/anti-boiling properties of the stuff but some corosion inhibiters might be nice. I am also concerned about algae growing in the water. It doesn't get hot enough to kill the stuff but the ambient temperture here is perfect for it. If I don't find a suitable anti-freeze I might just go for adding a little chlorine based bleach (NOT the 'oxygen' stuff). A little further reading on Wikipedia sugests that a weak solution of 200ppm Sodium Hypochlorite will be strong enough for bug killing but won't attack the metals. Standard household bleach is about 5% (50,000ppm) so a couple of tablespoons of bleach in 10l of distilled water should do the trick.
Thanks for all the comments from everyone so far, this has prompted some interesting reading.
22-05-2019 #7
You should be aware that Sodium Hypochlorite is somewhat alkaline in solution and hence will attack aluminium a bit. Should be OK on plastics and stainless steel though. Alternatively once the bleach is dissolved you could add a little acid to compensate - you should then have an essentially neutral solution containing some chlorine - how soon this would diffuse out through the piping though I don't know.
Water cooled vs Air cooled spindle for wood
By Bucks in forum Machine DiscussionReplies: 5Last Post: 06-02-2017, 01:58 PM -
Where to buy 2.2Kw Water cooled spindle + VFD
By RocketBoy in forum Marketplace DiscussionReplies: 3Last Post: 01-08-2016, 12:38 PM -
Water cooled / air cooled 2.2kw spindle
By suesi34e in forum Generic Chinese SpindlesReplies: 15Last Post: 25-02-2015, 04:57 PM -
Do you need to water cool erhm a water cooled spindle?!!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 18Last Post: 02-10-2013, 09:59 PM -
Cooling a water cooled spindle, without pipes everywhere & huge water tanks/buckets!
By HankMcSpank in forum Generic Chinese SpindlesReplies: 17Last Post: 18-09-2013, 06:32 AM
