Thread: Power supply for anodising?
23-06-2019 #23
Under some circumstances you (or more correctly your PSU if you've set it to constant current mode) will only be able to push the current to what the 720 rule suggests if you have some reserve voltage available, which may not be much on a 15V supply - I've found that in my bath I need 2 or 3V extra to get the recommended current, so I'd always recommend a 20 or 24V supply now. As for what you'll get on your 7in2 workpiece I'd reckon only 0.2A with 15V, which might be below the bottom end of the meter on your PSU - I doubt if it's amazingly accurate down there. Now then, can you see any fizzing/fine bubbles coming off the workpiece/cathode? if so, then you'll be doing some anodising. If you want to check your PSU, get a couple of 10 ohm power resistors and connect one across the terminals - with the supply set to constant voltage it should draw 1A at 10V, 1.5A at 15V. If you set the supply to constant current then you should be able to set it to 1A (voltage turned right up) with one resistor - if you now add the second resistor in parallel the current should stay the same. If you want to monitor the current on you car charger you could simply add something like this in series with the bath:
https://cpc.farnell.com/hobut/f3pam6...548?st=ammeterLast edited by Voicecoil; 23-06-2019 at 09:32 AM.
The Following User Says Thank You to Voicecoil For This Useful Post:
Power supply
By racerbear02 in forum Laser Machines & BuildingReplies: 0Last Post: 13-09-2015, 09:27 AM -
FOR SALE: power supply
By Web Goblin in forum Items For SaleReplies: 0Last Post: 14-09-2014, 03:19 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
