Page 3 of 3 FirstFirst 123
  1. Ok. I think this is max speed for a rigid tap at 6mm diameter
    1200 rpm
    https://youtu.be/mhANVN6tvCI
  2. Added one of my probes tonight :-)
    Triac is coming on nicely now :-)
    Even made the tapped probe plate on it ( small steps but huge to me)
    https://youtu.be/gcapYA04i14
  3. #23
    Are you sure your spindle only goes one way?
    I'm pretty sure mine had a reversing relay, but I've not got the wiring diagrams handy to check.
    For rigid tapping, you need reasonably accurate spindle control, along with accurate positional feedback, which the original DC motor definitely doesn't, and I'd suspect a VFD may struggle to respond fast enough, plus you'd struggle to fit a normal AC motor.
    I fitted a 110 frame 1.25kw servo motor to mine, which involved making up a quite substantial adapter (I do have a thread on here with details/photos), as space is very limited.
    I've still not got as far as trying rigid tapping, but that is one of the reasons I fitted the servo, instead of repairing/replacing the original motor and drive.
    I have a 1990 Triac, i want to change the spindle motor aswell. Did you change the complet fanuc mainboard, or just huck the new servo in the fanuc system? It would be great if you show me how you did it.
    I hope on your reply
    best regards
    Paul
  4. most of us have put newer easier to manipulate controls in. hacking fanuc stuff is hard work!
    mine is running uccnc on uc300eth motion controller.
    if you can find an 80 frame size servo for spindle it will bolt straight on with a adapter plate.
  5. #25
    Okay thanks. Did you keep the other motors? I have fanuc servomotors they work pretty well is it possible to keep them or is it better to throw all out and put a new controllboard and servomotors and drives inside?
    Thanks a lot for your support.
  6. #26
    Lives in East Lothian, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I retrofitted mine with a Dynomotion KFlop.
    Details of the new spindle motor are buried somewhere in this thread - http://www.mycncuk.com/threads/10344...ofit-thread%29
  7. Quote Originally Posted by PaulMucCNC View Post
    i re used the fanuc red cap motors but used new programmable drives to achieve this. works very well.
    the drives are not easy to set up. but ok if you know exactly what your doing.
    if not probably easier to buy matched motors and drives and swap them over.
  1. FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
    By Piero franchi in forum Items For Sale
    Last Post: 14-02-2017, 04:47 PM
  2. FOR SALE: Denford Triac + Denford Orac + other stuff
    By Clive S in forum Items For Sale
    Last Post: 06-02-2017, 11:47 PM
  3. Denford Triac - Help
    By mikeadams1985 in forum Denford Mills
    Last Post: 12-01-2017, 10:06 AM
  4. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
