Page 3 of 10 FirstFirst 12345 ... LastLast
  1. #21
    You're absolutely correct, and I've fallen foul of my own criticism of assuming too much. Looking at the board the axis drives are presented onto the IDC headers (the 16-pin black connectors, 5-of) on the board. Okay, that gives us a bit of an issue to understand how these are wired.
    I'm guessing there are at least 3 ribbon cables normally plugged into these (I think I did see this on an earlier piccy).
    I'm going to change tack back to the e-stop, but I'll post this for now knowing that you're stood in front of the machine scratching your head. Give me 20 minutes to write up another thought.
    No rush - I got plenty of other broken things around the shed I can stand in front of, when ever you get a chance is fine.
    There are ribbons normally connected to them, I removed them for the photo (numbered them to insure they go back in the right place)
  2. #22
    The ribbons go to these black boxes - I can draw a rough wire diagram of helps?
  3. #23
    the black boxes are the stepper drivers. they in turn are connected to the motors
  4. #24
    Quote Originally Posted by johngoodrich View Post
    I’ve tested these before and they had 5v from memory
  5. #25
    First thing - have you checked the integrity of the fuse, F1, on the board?
    Okay, I'm going to post a link to another site that has the schematic for a Syil 4 axis controller board - for no other reason that it will give a good idea of the pinouts of the IDC headers
    https://www.cnczone.com/forums/syil-...lp-please.html
    The pin bindings are clearly different from this BOB to the BOB on the Syil 4, so I cannot determine which pins on the IDCs are STEP and which are DIRECTION, but I can say that these are EITHER pin 1 or pin 3. Pin 2, 4 and 6 are set to +5V (so the step/dir will be driving the cathode of the opto-isolator on the stepper-drivers in the machine, low-side switching). Pin 5 confuses me - it's a common pin across all axis connected to a 3-pin connector on the 4-axis schematic... possibly an Enable signal to the stepper drivers. Now, I would ask for an image of where ONE of the three ribbons plugs into on the other end - Im expecting into another PCB or a module, and I'd be particularly interested any marking/engraving. ...ah, you've posted already. So you could perform the original tests against both pin-1 and again against pin-3 on the IDCs - one should behave as expected, the other won't.
    But, now we know more about your pin mapping and an awful lot more about your BOB, I'd be keen to change from looking at motors and more against the e-stop. It's easier to apply some logical diagnostics against and understand the apparent total lack of interface with the PC.
    So, starting again:-
    1) Establish a supply ground (we know the BOB is AC driven with onboard rectifier/regulator), so we need a signal ground. You've suggested that you have already measured board supplies etc - do you have a DC ground available to you?, I'll assume you have - you can pick one off the GND on the spindle connector, the centre pin on the 3-pin TO220 packaged regulator, or the "-" pin on the chunky capacitor.
    2) Establish which is the signal wire on the ESTOP input to the BOB - measure between either wired input on ESTOP and ground, with the ESTOP activated, and not activated. One of the pins should be consistently 0V (according to that schematic), and the other should switch between 0V and 5V depending on the ESTOP button position. Confirm this.
    3) with the IDC ribbon to the DB25 connector for the parallel port on the Syil connected to the board, but with the parallel printer cable disconnected, then I'd measure the voltage from 0V to pin 11 on the parallel port connector on the Syil. Confirm that this changes from 0 to 5 or vice-versa on the actuation/release of the E-Stop.
    4) Connect the printer cable from the Syil to the PC. Confirm the behaviour of the Estop control within Mach3.
  6. #26
    https://www.cnczone.com/forums/syil-products/114477-syil-sx3-bob-pinout-help-please.html
    The pin bindings are clearly different from this BOB to the BOB on the Syil 4, so I cannot determine which pins on the IDCs are STEP and which are DIRECTION, but I can say that these are EITHER pin 1 or pin 3. Pin 2, 4 and 6 are set to +5V (so the step/dir will be driving the cathode of the opto-isolator on the stepper-drivers in the machine, low-side switching). Pin 5 confuses me - it's a common pin across all axis connected to a 3-pin connector on the 4-axis schematic... possibly an Enable signal to the stepper drivers. Now, I would ask for an image and of the three ribbons plugs into on the other end - Im expecting into another PCB or a module, and I'd be particularly interested any marking/engraving. ...ah, you've posted already. So you could perform the original tests against both pin-1 and again against pin-3 on the IDCs - one should behave as expected, the other won't.
    Can a bolt on the frame be used as ground? If so neither have power (I tested bolt to a known power and it showed its power so I take it as the bolts grounded?)
    Just my spindle doesn’t have a middle pin and I think I’ve located this capacitor you speak of but unsure where it’s - is?
    I’ve tried a few different things and it’s weird
    I used pin 4 on the spindle connector (because it has a green and yellow wire coming from it?) with estop on both are 13v and off both are 10v
    If I go from the bolt (is reading different then when I first did it above) with estop on both are 0 and estop off the red one is 11 and the white wire 0
  7. #27
    Estop off
    Red wire
    White
    Estop on
    Red
    White
  8. #28
    So estop off and disconnected from the pc
    White wire to pin 11 is 1v
    Estop on is 0
    By white wire I mean this pin
  9. #29
    Cable removed from machine
    Estop on 1v
    Estop off 0
  10. #30
    Machine and cable connected to pc and nothing shows in Mach 3
  1. syil x4
    By geoff in forum Machine Discussion
    Last Post: 30-11-2016, 07:35 PM
  2. FOR SALE: For Sale Syil X7 plus CNC Milling machine
    By dpcwright in forum Items For Sale
    Last Post: 13-09-2015, 02:27 PM
  3. Syil x4 or x5 as CAD/CAM training 4 axis CNC machine ???
    By towdi.arek in forum Marketplace Discussion
    Last Post: 20-07-2013, 07:26 AM
  4. What i am doing wrong with mach3?? trying to config machine.
    By scnc in forum Artsoft Mach (3 & 4)
    Last Post: 31-01-2013, 05:01 AM
  5. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
