Thread: First Proper CNC Router
Found a little bit of time to wire up the motor on X axis (side to side one on the gantry) to see something moving.
I very quickly seamed to find the limit of these motors+drivers+screws at between 4000 and 5000mm/min (800-1000RPM at the motor). I was hoping for a little more than this. Acceleration is down at 20mm/sec2.
Do these sound like reasonable numbers when compared to other similar machines? Im a little more used to deal with lightweight 3D printers which are happy fly around at 150mm/sec+ all day. Guess a heavy CNC is a totally different animal though.
Spec is; 3.1Nm Nema 23 wired in parallel, 3.08A peak driver current, 68Vac, 1600 steps per rev (1/8th micro stepping), 1:1 belt drive, 1605 screw.
I know 1610 would be much more appropriate, but 1605 was sooooo much cheaper!
Motors are rated to 4.2A, so I could push the peak current upto 3.77A. Would heat dissipation become an issue running at 90% the rated current?
A quick google seams to suggest around 1000RPM is the limit before torque starts to drop of significantly, so im starting to think this is the genuine limit of the motors.
Its bloody loud too! Was expecting digital divers to be nice and quiet! I know increasing microstepping would help. What microstep settings do other people use?
04-12-2019 #2
My machine is a very similar size, and also with 1605 driven 1-1 from a NEMA23/3Nm. I get around 5000mm/min as well, although I haven't really tried winding it up much more as that is about as much as the long axis will take anyway. That was my design goal in any case as, as you say, that is about the corner speed of those motors when they start to lose torque. Can't remember the acceleration I'm using - I'll try to check next time I fire it up.
Brian's law of motor current tuning is - "keep winding it up until it starts to get about as hot as you can comfortably hold when it's been running for a while." I'm not sure how accurately those driver current limit numbers are given that they are averaging a pulse output, and the motor current ratings are RMS? Peak? Who knows - the only issue is whether or not they get too hot in practice! Stepper motors are designed to run hot and mine have run using that adjustment technique for a few years now with no apparent ill effect. As for noise - that one's very difficult to judge!
05-12-2019 #3
I'd be interested to know where you found cheaper 1605 ballscrews. A quick scan of Fred's BST Automation's site has 1000mm long ballscrew sets of 5 and 10mm pitch at $148 AUD and $135 respectively, including delivery to Australia. Interestingly he also has 1616 screws for those wanting an ultra-fast machine.
05-12-2019 #4
Ebay.
850mm 1605 screws are just £30, and are delivered from the UK so no need to worry about getting stung with import tax.
To my in experienced eye they seem ok. Were packaged well, and dont appear to be to bent.Last edited by diycnc; 05-12-2019 at 07:33 AM.
NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
By SweetAs in forum New Member IntroductionsReplies: 27Last Post: 16-02-2019, 12:06 PM -
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
what router can i use with openbuild ox gantry router?
By davejavu123 in forum OpenBuilds OX CNC MachineReplies: 5Last Post: 13-08-2015, 01:40 PM -
eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
By Deuce_Coupe in forum Items On eBay UKReplies: 0Last Post: 16-07-2014, 11:46 AM -
Woo, my first 'proper' part!
By craigrobbo in forum Woodworking Project ShowcaseReplies: 29Last Post: 05-08-2012, 02:51 PM
