    Quote Originally Posted by chillybo View Post
    Thank's, cropwell so you have separate switches for homing and limits? From what I've gathered you can use the limit switches also as home switches (the home command initiates the desired directions of each axis). Is your design based on increasing safety / reducing risk of damage to the machine? As in the limit switches are placed slightly beyond the position of the home switches.
    The main advantage of using separate Limit switches is that you are protected while Homing. When the switches are shared for both Homing and limits then Limits are Ignored While Homing so it's not quite as safe.
    That Said the advantages of using Shared switches, Esp if you use Single switch that travels with axis and searches for Targets at each end of travel is much simpler wiring with less chance of wiring errors, Also lower costs.
    Regards which switch type to use then it's a personal choice. My personal preference is the Proximity switch because they are accurate and cheap. Also simple to mount.and don't have some of the issues mechanical switches can have.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    AND I would add, less to go wrong over time.
    Thanks for this Jazz this makes a lot of sense and gives more flexibility of where to locate the proximity switch on my machine.
  1. Proximity wiring for limit switches, safety relay and a contactor
    By CharlieRam in forum General Electronics
    Last Post: 02-06-2019, 11:18 PM
  2. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  3. Help needed with proximity switches
    Last Post: 11-07-2014, 03:29 AM
  4. Proximity Switches
    By kingcreaky in forum General Electronics
    Last Post: 23-10-2013, 01:30 PM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
