Page 3 of 23 FirstFirst 1234513 ... LastLast
  1. #21
    I got mine from Simmal (you might need to email/ring them as they don't keep everything ont' website), I suspect other places like DoRé Metals & Smiths might have it too.
  2. #22
    Quote Originally Posted by devmonkey View Post
    I'm also sure I've seem some pictures on here of peoples gantries constructed from plate?
    Yes probably seen gantry I've shown built from plate and few others used it or adapted to there machines. It makes for a very stiff gantry,
    However, it needs a lot more work compared to HD profile. I've used all methods of constructing gantry's and HD profile is by far simpler with more than enough strength for any Router cutting materials up to Aluminium.
    Aluminium Rect section doesn't compare to HD profile in terms of resonance and vibration dampening and this is should be more of a concern than twisting deflection you seem to be chasing if you want a good Router.
    There is no cutter you will use that will withstand forces enough to twist a gantry made form any of these materials before it snaps. However, Resonance will affect any cutter and the smaller the cutter the worse it gets. My advice is to Stop chasing twisting etc and look more to lowering resonance if you want a good Router.
  4. #23
    That's an interesting point and worthy of investigation. I've saved the impulse response files from a length of the 6 x 3 x 3/8 box, does anyone have a short-ish (~600mm) length of 160 x 80 profile they can lend me to do a comparative measurement?
  5. #24
    Hi Jazz,
    Thanks for the advice. Do you have any pictures or wise words on how a 'stiff' gantry was made with plate? From the calculations I did a simple channel from 16mm plate is not sufficiently stiff in torsion at 1/10th that of 160x80 profile.
    I'm trying to reuse a set of HGR15 rails left over from another project on the Y. These were originally purchased to replace rails on a much larger machine that had rusted badly, since then that machine has been written off.
    15mm rails are too narrow to go over an 8mm slot, this means they will need to be drilled and tapped into the centre flat section between two slots or another plate milled to bridge the slots and then mounted to that. If the latter then it isn't much more work to mill up a front plate as well.
    If I already had 20mm rails for Y then the profile would be a no brainer as the rails could be bolted straight into the slot.
  6. #25
    Right I've made a decision!
    I called around a load of my usual aluminium guys, Smiths, Aalco, Blackburns, plus a couple of local metal shops. No one has any 6x3x3/8 box on the shelf (even Aalco who have a warehouse near me about 10 acres in size) and although they could get it I would need to buy a full length. To be fair I didn't try Simmal.
    I've built two previous machines using 6x2x1/4 box and they worked fine albeit I had to shim the rails, only very slightly as I didn't have a mill back then and I had to bolt blocks into the ends to bolt into (not required on the 3/8 box). Anyway I'm just going to go with the original plan from the first post in this thread, will order some 160x80 Item heavy clone from KJN tomorrow.
    I will first try to just mount rails directly to the central flat on the profile, if this turns out too wobbly I will plate over the slots and fix rails to plate.
  7. #26
    I've started milling parts for the Z.
    Front plate and rail spacers finished, all fits well. These large plates take an age to mill out on my manual mill.
Name:	IMG_20191213_160407 (Large).jpg
    At least drilling the holes accurately is simple with the DRO.
Name:	IMG_20191211_155053 (Large).jpg
    Also took a delivery of bolts for the machine:
Name:	IMG_20191213_160600 (Large).jpg
Name:	IMG_20191213_161425 (Large).jpg
ID:	26857   Click image for larger version.
Name:	IMG_20191213_160412 (Large).jpg
ID:	26858   Click image for larger version.
Name:	IMG_20191212_150159 (Large).jpg
ID:	26859   Click image for larger version.
Name:	IMG_20191213_161442 (Large).jpg
ID:	26860   Click image for larger version.
Name:	IMG_20191213_171848 (Large).jpg
ID:	26861   Click image for larger version.
Name:	IMG_20191213_161928 (Large).jpg
  8. #27
    Finished the Z back plate so have now assembled the Z. Everything fits perfectly. All 4 long edges of the large front and back plates were milled in a single fixture so these will all be reference edges for aligning the rails and also tramming the Z on the gantry.
Name:	IMG_20191214_161417 (Large).jpg
    Pockets for the ballscrew mounts, these weren't perfect were supposed to be 1mm deep, infact 1.28mm so will need a thin shim between front plate and ball nut holder. TBH ballnut holder is not a precision item, rather it is a cast lump, so probably would have needed shimming anyway.
Name:	IMG_20191214_161439 (Large).jpg
Name:	IMG_20191214_160624 (Large).jpg
ID:	26872 Click image for larger version.
Name:	IMG_20191214_160503 (Large).jpg
ID:	26873 Click image for larger version.
Name:	IMG_20191214_160353 (Large).jpg
ID:	26874 Click image for larger version.
Name:	IMG_20191214_160341 (Large).jpg
    I'm now waiting on the extrusion to arrive for the gantry as I need this to measure off for the Y bearing plates, gantry end plates, etc. Hopefully should be here early next week.
  9. #28
    How do I make the images in these posts larger rather than just thumbnails?
Name:	IMG_20191214_160341 (Small).jpg
  10. #29
    Joe,
    That's looking very impressive.
    Clicking on the thumbnails takes you to the larger versions which, on my laptop at least, are sized to fit the screen. Clicking again will enlarge them to what looks to me to be 'actual pixels' size.
    Kit
  11. #30
    Joe,
    Kit
    Hi Kit, I actually meant how to inline images in posts larger than thumbnails, other people seem to be able to do it.
    Machined up the Z stepper plate this morning.
Name:	IMG_20191215_123224 (Large).jpg
ID:	26878 Click image for larger version.
Name:	IMG_20191215_123246 (Large).jpg
ID:	26879 Click image for larger version.
Name:	IMG_20191215_123301 (Large).jpg
  2. BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
    By oliv49 in forum DIY Router Build Logs
    Last Post: 08-06-2018, 01:18 PM
  3. welding steel base or just getting aluminium extrusion
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 15-01-2018, 08:55 AM
  4. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  5. Steel vs Aluminium
    By gavztheouch in forum Metalwork Discussion
    Last Post: 26-05-2014, 10:11 PM
