31-01-2020 #5
If you use 80x80x3mm or 100x100x3 / better IMO/ then there will be no need for bracing and triangulation which will simplify greatly the build.
Even 60x60 a bit thicker or properly spaced is ok but i prefer the above for simplicity. Avoid triangulation for simplicity's sake.
There are many designs but the design that Dean shows above is my favourite for a DIY router. Especially due to the fact that is more dust and liquid resistant than any other. Plus easier to achieve high precision than others. And most people here even do it so you could move bed up and down.
Some thoughts on cnc machine design principles. . .
By routercnc in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 09-10-2020, 10:59 AM -
Any ideas or thoughts on making a edge finder come touch off tool
By suesi34e in forum Electronic Project BuildingReplies: 26Last Post: 01-01-2020, 06:28 AM -
Advice & thoughts please on this 5-axis design
By Plaxton in forum Machine DiscussionReplies: 3Last Post: 07-12-2019, 08:19 PM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM
