    My point was there's no more hassle using Absolute than incremental and there's actually less wiring required because you're not fitting home switches etc.
    You still need a homing switch to setup the absolute encoder reference. The only difference is that you don't need to home on subsequent power ups.
    Quote Originally Posted by jarjar View Post
    Been told doesn't need a physical switch the system just needs to be calibrated with encoder offset for the home position which can be obtained through software..! . . . I will find out soon enough.
