    I have some hybrid steppers not used them before and I'm struggling to get them to do anything,they have power and lock just don't respond to mach3, I presume I don't need the enable line
    I must be doing something wrong with the C's labs control or wired incorrect
    Any help once again would be great
    I do have the input switchs working for probe,home,end stops etc and the output to switch a relay etc
ID:	27665   Click image for larger version.
    Have you selected the "Enabled" (green tick) in mach3 ports n pins - motor Outputs.? This is all you need to do in Motor Outputs, forget the Step/Dir and Port pin numbers etc they are not used, (except the active high if need to change the step edge which can get into later if needed )
    That's all you need to do for the motors to work. Then you just set the steps per and tune the velocity etc in motor tuning.
    Also, watch those straggling wires, if they short you'll blow the drives.!
    [QUOTE=
    Also, watch those straggling wires, if they short you'll blow the drives.![/QUOTE] i knew that would be brought up :) i will sort them was just a quick bench test
    i watched your you tube of of the motor and port settings,i have the green tick, carnt remember the rest im at work atm
    will check the rest once home, i thought this would be easier than it is with the ports and pins being out the door
    thanks
    Quote Originally Posted by gregors View Post
    Ye but they blow up just as quick on the bench as they do in the control box.!!. . Only takes 1 strand to release the magic smoke..
    Like I say for the motors you only need to enable each Axis in Motor Outputs all the rest you can ignore.
    seems like channel 0 has gone down, as they work on others :(
    I've had things like this happen before. Try reinstalling Mach3 and the Plug-in with a fresh install ie: Delete the old first and Don't install the parallel port driver when installing mach3.
    If still does it then I'd say yes could possibly be faulty but I'd be very surprised. I've fitted Dozens now and never had a faulty unit, I've killed a couple but that was my fault.!
    i will try that as its had a few other plugins installed
    thanks
    Hi and first thanks for your help :)
    I have 4 drivers like this too, the enable pins aren't necessary?
    In my last setup with arduino i used this connection:
    And worked fine.
    With CSMIO and this drivers what recommendation are the better, doesn't use enable pins or this one i take from csmio web:
    Thanks for your time :)
  1. Stepper Motor Wiring
    By ravihotwok in forum General Electronics
    Last Post: 26-07-2017, 10:41 AM
  2. Hybrid Stepper Servo
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 08-06-2015, 12:41 PM
  3. Stepper motor tunning wiring
    By handyoodman03 in forum Stepper & Servo Motors
    Last Post: 11-01-2013, 05:49 PM
  4. CY or SY cable for stepper motor wiring?
    By Jonathan in forum General Electronics
    Last Post: 26-09-2010, 06:25 PM
  5. Stepper motor wiring
    By Buba b in forum Stepper & Servo Motors
    Last Post: 28-03-2010, 06:16 PM
