29-03-2020 #41
There is NO misunderstanding Kit we know this very well, the point was why use an oversized PSU that costs more money when not coming close to using the maximum output of the original.?
Regards your and DazP # of PSU's, which was the other point of my objection, you are still producing heat and burning electricity that isn't required. Heat is the enemy of electronics so anything that lowers it can only be good.!
. . . . Next you will all be telling people Bigger steppers are better.!
29-03-2020 #42
I would presume that an SMPS when off load only draws enough input power to keep the output stage at voltage. Off load the efficiency will therefore be 0. The current drawn from the mains will be enough to compensate for leakage in the output capacitor(s) and this will depend on the design of the unit and the quality of the output stage electrolytics (in the main).
Similarly in a transformer based supply, in an off load situation the self inductance of the primary will limit the input current, but not as much as an SMPS in the same state. Again the idle current will be dependant on the transformer design.
Are these valid assumptions?
Rob.
29-03-2020 #43
29-03-2020 #44
29-03-2020 #45
Nooooooo.
Bigger steppers are crap! unless you supply them with a very large voltage. Especially those 1700oz things with 8mh inductance from China. Seen a few make that mistake.
As for the PSU I don't see many of them that have failed unless they're running close to or over capacity. If the machine has car type relays in use and/or a few of them, then they may suck life out of it. If this is the case you're either replacing all the relays or going with a bigger supply (what's cheaper). (At least I only went 38w more! lol) Trace your wires and check what's in use.Last edited by dazp1976; 29-03-2020 at 05:10 PM.
29-03-2020 #46
My point about automotive relays is that they draw a lot of current, some of them nearly 1 amp. That may damage the electronics that feed the coil. I am not concerned about PSU capacities, more than the BoB. In this case I do not know where the relay is fed from.
In fact I have spotted two of the little buggers in the photos, there may be more.
29-03-2020 #47
Gods I'm bored being home-bound. Bored enough to look on Farnell and RS at both power relays and automotive - to be honest there's not an awful lot in it - which looks to be more around the switching capacity (not really surprising) and what you could imagine the associated switch gear and return springs, and with most of the 50A relays around the 90R coil resistance (around 130mA). Automotive are likely more suited to the environment (high vibration, humidity and corrosion resistance) as well as providing economic switching of the high capacity PSUs we all tend to have knocking about.
02-04-2020 #48
afternoon all hope you are all keeping well
psu arrived lunchtime all wired up machine working as it should
many many thanks to jazzcnc and Clive your persistance with me has now got my machine up and running sorry i was a pain but with your help and knowledge we got there when all this lockdown is over if you are down my way Barton on sea give me a shout i owe you guys a beer or two
Great Forum
thanks Geoff
02-04-2020 #49
Your Welcome Geoff pleased your making chips again. Take care and stay safe.
02-04-2020 #50
thanks jazz
mach3 won't reset
By dougberrow in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 27-05-2019, 11:25 PM -
Help needed with Mach 3 - reset external flashing light
By Tom J in forum General ElectronicsReplies: 7Last Post: 26-03-2017, 08:34 PM -
Sieg KX1 & Mach3 won't come out of emergency reset
By lateAtNight in forum Gantry/Router Machines & BuildingReplies: 32Last Post: 19-06-2015, 06:37 PM -
Please help me... It wont work.
By kingcreaky in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 22-01-2014, 10:42 PM
