    Hi John
    Regarding vertical mounting you will have to build yourself a substantial base, if you make another post asking for ideas for designing a vertical assembly machine Dean(JAZZCNC) might give you some advice regarding this, he has a video of one of his larger builds but i couldn't find it.
    Regards
    Mike
    That would probably be this 8x4 then. 10 x 5 with a Vacuum bed will be coming soon if I ever get out of this bloody house again.!!.
    The vertical machine works amazingly for large machines with no downsides other than cannot use it as a bench. The advantages are many and I wouldn't go back to a horizontal machine if larger than 4x4. That said I'd still have a vertical machine under 4x4 for some of the hidden benefits like longer tool life and better chip management but below 4x4 the space-saving isn't so great.
    Regards the filling of tubes then I've tried sand and while it does help a little it's not a massive difference. Don't fill tubes with concrete because it can shrink, it also doesn't mix well with aluminum. Expanding Foam and Silicone etc don't do diddly squat so don't waste your time money.
    The best thing I found is to use a thicker wall tube in the first place and brace it well. Regards the aluminum profile then if you use HD version then you shouldn't have any issues with vibrations and I don't think to fill the voids with Epoxy granite will dampen to any great degree but it will certainly affect performance because of the extra weight.
  2. The Following 3 Users Say Thank You to JAZZCNC For This Useful Post:
  1. Aluminium profile cnc build
    By valdis034 in forum Gantry/Router Machines & Building
    Last Post: 21-02-2023, 02:27 PM
  2. BUILD LOG: First Build - Yet Another Alu Profile Router - 900 x 800
    By CaptainBarnacles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 08:16 PM
  3. BUILD LOG: Large aluminium profile build
    By jeronimo in forum DIY Router Build Logs
    Last Post: 12-11-2016, 10:02 PM
  4. BUILD LOG: New build - fixed gantry mill using extruded profile
  5. NEW MEMBER: John C, York, UK
    By JohnC in forum New Member Introductions
    Last Post: 17-10-2010, 07:03 PM
