    Hi Ian,
    You're missing a key bit of information - how are the screws retained axially?
    Typically people use a fixed block at one end (often the driven end) and a floating block at the other. These are often of the FK/FF or BK/BF variety.
    You might be able to feel the screw moving backwards and forwards as you pull on it with 0.15mm of backlash, if so that would imply you need to look at the screw rather than the ball nut.
    ian's Avatar
    Lives in London, United Kingdom. Last Activity: 23-12-2025 Has been a member for 5-6 years. Has a total post count of 25.
    Hi Ian,
    Hi Andy UK
    It has a fixed FK at one end and a floating block at the other end which I cut myself. There is no play on the ballscrew, in fact on inspection it seems that there is a bit of compression on the ballscrew and I will spend some time on the weekend to troubleshoot it.
  1. Cutter accuracy
    By Neale in forum Tool & Tooling Technology
    Last Post: 02-09-2017, 03:23 PM
  2. Cut depths and spindal speeds to improve finsh time
    By Fivetide in forum Tool & Tooling Technology
    Last Post: 21-05-2015, 08:39 AM
  3. Improve Kress TIR or get an upgrade?
    By Hauk in forum Kress Milling Motors
    Last Post: 23-02-2014, 06:18 PM
  4. trying to improve my board game
    By cubikoman in forum General Discussion
    Last Post: 12-05-2012, 06:57 AM
  5. NEW MEMBER: cubikoman needs to improve quality of his boardgame
    By cubikoman in forum New Member Introductions
    Last Post: 16-02-2011, 12:17 PM
