Thread: 3 Axis CNC router
The motors are soldered to the cy cable and are wired directly to the drives - no connectors! And the cy shields are grounded at a star ground in the cabinet.
But... The frame is not grounded independently come to think of it, should I take a connection from the steel back to star ground? Is that what you mean by chassis?
I will go hunting for loose connections but pretty sure they are all good as I checked last time I had issues...
The last time (previous post) when I stopped the machine after noticing a problem, it carried on doing these movements after both feedhold and stop, it was only the estop cutting power to the motor that stopped it.
16-06-2020 #2
Yes, run a wire from the Star point to the Frame and if you want to take the belt n braces approach then run another to the gantry just in case it's not earthing thru the bearings very well.
Do this before doing anything else. That way you'll see if your problems go away just from this.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
There are currently 20 users browsing this thread. (0 members and 20 guests)
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
