Thread: Driver help
06-03-2021 #11
Thats exactly what I have now. Seems to be ok except I think the y axis has blown. Im going to try using the b axis output this afternoon, and If that works ill buy another couple
06-03-2021 #12
It's certainly possible to blow a single output - though a little unusual. Definitely worth substituting B - yup. If you still have a problem then think of the signal chain (for example, you could use another channel on the UC300 - just remember not all are the same, but there's at least 2 with the 11-outputs/5 input configuration.
06-03-2021 #13
Yep I tried changing from port 2 to 3 but no difference
06-03-2021 #14
I've just read the thread through - yeah, try changing the outputs still, but keep in mind the stepper drivers. In a pinch, I'd try disconnecting the step/pulse input to the driver and just flashing 5v across it (make/break with a bit of stripped wire) - all correct polarity of course. Quick way to check that the driver hasn't been borked along the way. Zero-cost, removes a component from the diagnostics.
06-03-2021 #15
I used z wiring on the y driver and it works so definately the bob
06-03-2021 #16
Well I've sorted the issue. Turns out the new cat 5 cable i used to wire the drivers had a break it it somewhere. Used a new bit of cable and success. Doddy, do you use the screw terminals or do you have connectors to plug in to the board?
06-03-2021 #17
I tend to use the screw terminals (with ferrules), bit daft since I have the connectors (I think). But screw-terminals allow you to maintain things with a banana, at a push :)
06-03-2021 #18
Do you know what type of connectors they are?
06-03-2021 #19
06-03-2021 #20
That rings a bell, I'm sure someone else had a similar problem a while back. Was it monofilament cable?
I've got one of these which turns a laptop into a two channel oscilloscope and has proved invaluable for tracing pulsed signals and would have found your broken wire very quickly. No doubt there are those who will say it's too complex a bit of gear for some people to use but in trying to fault-find on a CNC router you are already dealing with a complex bit of gear and need the right tools to show you what's going on. It's part of my standard electronics tool kit along with my multimeter and soldering iron. Is it expensive? Depends on how much money you would have wasted on replacing BOBs, drivers and other components that were never faulty.
Kit
https://au.element14.com/pico-techno...g/dp/236542501An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Driver led's
By Duffman in forum Motor Drivers & ControllersReplies: 5Last Post: 16-01-2016, 02:41 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Dc servo driver
By Treemonkey in forum Motor Drivers & ControllersReplies: 11Last Post: 11-02-2013, 08:16 PM -
Driver Lights Red
By Toddy in forum Motor Drivers & ControllersReplies: 6Last Post: 05-11-2011, 03:46 PM -
Driver box
By John S in forum General ElectronicsReplies: 1Last Post: 21-06-2009, 12:46 PM
