02-05-2021 #9
Surprisingly it does Muzzer.! . . Esp with a stepper system on long screws and smaller steppers feel it the more and really struggle with it if the pulleys are heavy. This is why when building machines with long screw lengths and steppers, (over 4ft) I select a higher pitch screw and use a ratio to lower screw speed, this serves 2 purposes, lowers the chance of screw whip and lowers the inertia.
I also only fit Nema 34 motors which use high voltage drives, often these are at mains voltage depending on motor size 8nm + but for the smaller 34's I still wouldn't use drives less than 80Vac/100Vdc. The 4.5Nm and 5.5Nm Nema 24 Closed loop Lichuan motors I use now are so powerful running on 60Vac that I rarely fit Nema 34's below 8nm as the difference they allow in performance is much better.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
There are currently 12 users browsing this thread. (0 members and 12 guests)
Carbide taper ball nose cutters
By Leadhead in forum Tool & Tooling TechnologyReplies: 2Last Post: 08-01-2020, 06:45 AM -
Is there a Lee on eBay from china who is good for ball screws and guides from please?
By suesi34e in forum Rails, Guideways & BearingsReplies: 1Last Post: 13-11-2015, 12:40 AM -
have you put ball screws on an X2plus?
By bmbaz in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-05-2014, 06:56 PM -
buying ball screws
By bmbaz in forum Marketplace DiscussionReplies: 2Last Post: 10-05-2014, 03:57 PM -
Best way to machine ball screws?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 34Last Post: 17-06-2012, 05:10 PM
