Thread: AXBB charge pump fault
17-11-2019 #61
Ok, bear with me as I'm still learning...
The voltage across the resistor was 0v when off and 4.65v when on
With the relay and resistor connected the voltage was about 1v when on and 14.7 when off (between op1 and -24v)
With the relay disconnected it was 0v both on and off
Sent from my SM-G920F using Tapatalk
17-11-2019 #62
"The voltage across the resistor was 0v when off and 4.65v when on "
is what I expect between the FET gate & source
when the CHP 01 is switched off and on
"With the relay and resistor connected the voltage was about 1v when on and 14.7 when off (between op1 and -24v)"
implies the FET is leaky and not switching off completely
when working correctly
the FET's ON resistance should be 155 miliohms
as the relay coil resistance is 650 ohms
at 24V DC
the relay coil and 27 ohm resistance should pass around 35.5 mA
the volt drop across the FET when switched on will be
0.155 ohm x 0.0355 A = 0.0055 V = virtually zero on a basic multimeter
either the FET is not switched hard on so the on resistance is higher
or your measurement includes the volt drop across your wiring and contact resistance of the connections
"14.7 when off (between op1 and -24v)"
when the FET is off no current should flow through the 27 ohm resistor and 650 ohm relay coil !
to measure 14.7V at the output
24- 14.7 must be dropped across the total 677 ohms of the relay coil and resistor
the leakage current must be 9.3/677 =0.137 A
so instead of the FET looking like its open circuit when off
its more like a 107 ohm resistor !!
"With the relay disconnected it was 0v both on and off"
is correct
the FET acts as a switch between the -24V/common
and the CHP O1
without the relay being connected
there is nothing between the +24V and CHP O1 to pull the output up to the +24V supply
John
18-11-2019 #63
So you reckon the fet is borked again? I have stripped the control box back again but cant see any shorts and I'm remaking the control panel, mainly because the wire was too short but also I don't like the layout and realised it would be handy to have jog buttons for the axis as well as the hand held MPG. It also seems the perfect opportunity to start again and eliminate any issues although I've looked and can see no potential for shorts? I'm also going to add a slave axis to the machine. I am happy with it but I can see improvements and want to do it before the machine is working proper.
So back to the Fet...my mpg is wired up with a db15 connector, I wanted to extend the wire longer so tried a male to female db15(monitor) extension cable, it didn't work and the usb controller wasn't recognised in Windows until I removed it. That is the only thing that I can think went wrong....
18-11-2019 #64
The SVGA extension cable - there's a couple of no-connection lines in there - perhaps if those aren't wired-through it explains the inability to work. A straight-through 15-w D-type M-F should work without too much drama. Not sure what you mean by the USB controller - unless this is a Windows->pendant interface?, in which case, again, the lack of cabling may possibly explain that (not sure).
The FET behaviour, as described, is borked.
18-11-2019 #65
Sorry...i should of explained better. The pendant was one of these...
https://rover.ebay.com/rover/0/0/0?m...2F163108997386
The mpg is wired to inputs on the AXBB but the axis and jograte selectors are wired to a usb controller due to the lack of inputs on the AXBB. The svga wire was advertised as fully wired so I assumed that meant each pin was individually wired but I don't think it Is!
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 18-11-2019 at 08:40 PM.
17-07-2021 #66
It seems concerning that, regardless of the reason, failure of the charge pump output can result in an estop being ignored. I was planning on replicating OP's design with the charge pump output controlling my contactor. Now I'm not so sure. What are your thoughts on this?
17-07-2021 #67
1) This is the only instance I've heard of of the Charge Pump output failing.
2) Use a Safety relay to control your contactor, with the charge pump signal as part of an E-Stop circuit controlling the safety relay. Any E-stop drops the safety relay, which drops the contactor.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
17-07-2021 #68-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
17-07-2021 #69
Sorry old friend, didn't see the email.
Had a bad back earlier this year that put me out of commission for about 6 weeks. And projects at the new house have kept me incredibly busy.
The screenset is at the top of my todo list, as soon as I can find the time. Trust me, I want it done as much as everyone else.Gerry
17-07-2021 #70
The charge pump fault is now fully sorted, the only thing I can assume that caused it was a 15pin dsub extension cable which I used on my pendant, it seems not all of the 15 pins were independent, not had an issue since and repaired it with the help of this forum
Sent from my M2003J15SC using Tapatalk
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
