Hi Ben
Nice to see your work. I'm in talks with Dean at the moment regarding a CNC machine for me to make jazz guitars. A similar process in some ways to a Les Paul.
I noticed you have a lot of tooling marks left on the neck and further bits to sand, could I ask why that is?
I'm hoping that I can do necks with less work left after machining but I might be unrealistic about what I can achieve.
Issues for me would be that jazz guitars don't have have wings glued to the headstock and the heel is taller.
So without sounding like an arse, are the issues (you may not see it that way) you have purely down to lack of experience, or is it simply as you state, easier for you to do more post sanding. I'm hoping to do asa little sanding as possible as this adds in a margin of error and lack of repeatability.
Also how well did carving the top of the body go? Did you have to do a lot of post sanding to get rid of tooling marks or was it pretty much good to go?
Hi Archy,
That neck was finished with a 1mm steover parallel pass. I could have quite easily set it to something lower but it would increase machining time. Hell, I could have set it to 0.1mm stepover but personally I dont see the point. You are going to be sanding the neck anyways, It may appear to you like there are alot of machining marks, but 120 grit sandpaper will have that neck smooth in a matter of minutes. Plus, with something like a neck it is going to be refined further before completion, the shoulders of the neck will need blending with the fretboard as I have left the neck a little wide to give me a bit of wiggle room when glueing the fretboard on.
The top carve went really well. I believe on that I ran a "Morphed Spiral" operation from fusion 360 and in that instance set my stepover to 0.5mm as the top is maple so a bit more effort to sand. At 0.5mm stepover you would have needed a magnifying glass to see the scallops.
regards
Ben
20-08-2021 #3
First, let me say this post isn't intended to sway your buying decision because by now after speaking with you at length I'd like to think you realise I that's not my style or way.!
The surface finish you can achieve is all down to the size and step over amount, mostly this is a trade-off between time and effort in sanding. With a small stepover, you will get a finish that is perfectly smooth. However, the cycle time could quite easily quadruple or more. But it's certainly possible to get a perfectly smooth finish.
This trade-off between step-over and sanding is why in my post congratulating Ben I said "you seem to be getting to grips with it quick enough, those feeds n speeds look nicely dialed in with a good balance between speed and sanding regards the step over(scallop)" The time saved in machine time compared to the small amount of extra sanding required is in my opinion worth it provided it's used in the right areas.
This is the beauty of CNC and having your own in-house machine, you can decide where the accuracy warrants a smaller step-over and where you can tolerate a little more sanding to lower overall build time. Plus you can tweak fit etc.
Like most things in manufacturing, Quality is a trade-off between time and effort. CNC just allows you to choose how much of each you save.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Further Progress with my JazzCNC .. Guitar Body
By BeeceUK in forum Woodworking Project ShowcaseReplies: 7Last Post: 23-04-2021, 06:25 AM -
NEW MEMBER: Guitar Building CNC Newbie
By BeeceUK in forum New Member IntroductionsReplies: 18Last Post: 26-09-2020, 05:04 PM -
Jazzcnc, the right choice in a custom made machine
By alex wight in forum General DiscussionReplies: 17Last Post: 18-10-2016, 07:39 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
NEW MEMBER: CNC and other Machine Building Berlin
By Andikid in forum New Member IntroductionsReplies: 1Last Post: 07-10-2010, 11:30 PM
