Thread: 3000x1500mm table drawing stage
07-09-2021 #2
08-09-2021 #3
07-09-2021 #4
Stich weld it, here's a little program that will help you out https://www.stitchweldcalc.com/
Make your weld beads about 50mm long with a pitch of about 150mm. the calculator will tell you how many are required per length.
Tip: Chamfer the flat bar on the underside where your weld beads will be and you'll get a stronger neater weld with less distortion.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
08-09-2021 #5
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
Next stage is Plasma add on...
By Skiprat in forum Plasma Table MachinesReplies: 20Last Post: 05-04-2017, 11:31 PM -
eBay: NEAT XY-1010 xy table 8" travel very solid 17kg table NEW ebay.co.uk 251715555999
By emlclcy in forum Items On eBay UKReplies: 0Last Post: 12-11-2014, 09:14 AM -
BUILD LOG: Design stage of 4030(ish) for wood and plastic
By andy586 in forum DIY Router Build LogsReplies: 4Last Post: 14-11-2013, 10:07 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
