  1. Hi John,
    Ok I found some time this morning to look at my other verniers...
    There seems to have been an explosion of vernier types since I wrote the PIC code; I have half a dozen different verniers here with five different output formats! (including Mitotoyo, which is completely different) With your two that makes at least six 'chinese' formats. I have a one I bought in the USA with fractional inch display (very handy) that outputs fast 25mS pulses and, like your Aldi one, does not respond to clk or data switching.
    I think the best way forward, is to drop the automatic device detection from the PIC code and add some manual set up commands and a configuration page to the VB prog. (I want to add a DRO to my Haighton at sometime so it is something I will have to sort out).
    It would help, to know the switching sequences for your BCD one, so if you get the chance to work them out.... :)
    Bill
    Quote Originally Posted by BillTodd View Post
    Hi John,
    Bill
    OK Bill, I will do a controlled test of my BCD vernier to get the sequence and report back. I'll just code up a simple pulse generator in one of the PICs.
    I'm glad you mentioned that the mitutoyo verniers have a completely different protocol as I nearly bought a 24" one a few days ago on eBay. It was mainly for the bar/PCB but using the reader would also be good.
    btw. Good idea about having a manually selectable Vernier type in the VB app.
    Cheers, John
    Quote Originally Posted by 1113562 View Post
    Cheers, John
    OK I have done a test on the BCD vernier which is a Workzone 6" bought from Lidl or Aldi, can't remember which. I have attached an image of the state diagramClick image for larger version.
Name:	VBCD Vernier State Diag.jpg
    It starts always at power up in Slow Read mode. To get from switch on to Fast Read (F.T) needs a Data then a Clock Pulse. To Zero at power up on route to F.T then its Clock then Data then Clock. When in F.T. to Zero needs a Data then CLock then Data then Clock. There are other states as shown in the diagram that are of no interest to our use I suggest.
    John.
    John.
    This version of Vernier seems to be virtually the same state diagram as that on the YADRO site but they do not show some of the hold states.
    Hi John,
    Bill
    Just to get the record straight, I found by inspection that I had reversed clock and data from the vernier to the PIC processor inputs. A BASIC SCHOOLBOY error. On correction of the error Bill's HARDWARE & SOFTWARE works perfectly with dead stable values on the PC display and also fast update rate. Its a neat and dead cheap solution if you have a PC to hand with a serial COM port.
    I'm now going to sort out 2 more verniers that respond to clock and data mode pulsing so I can get X Y & Z working simultaneously. I'll then make a proper PCB for the interface rather than a veroboard prototype to make it a bit more robust. The next step will be to get it all installed on the mill with the full length PCB beams for each axis.
    A big thank you to Bill Todd, he is a genius and a gentleman in equal proportions.
  1. Website idea.
    By qwertyjon in forum General Computing
    Last Post: 05-04-2014, 03:29 PM
  2. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 01:05 AM
  3. Why they don't want to accept my idea?
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-07-2012, 01:15 AM
  4. business idea?
    By homer93 in forum Marketplace Discussion
    Last Post: 01-06-2012, 12:56 PM
  5. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 11:54 AM
