    Lives in Plymouth, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    If the copy of Mach3 came with the machine, is it a genuine licensed copy? There are quite a lot of "pre-licensed" copies around and they are notorious for giving weird results and inexplicable problems. One possibility is to download a genuine demo copy of Mach3, use your existing configuration files, and test to see if that works. Demo versions are limited in the length of gcode they can run but are otherwise fully functional so that would see if there is a Mach3 problem or not.
    it was given with product and looks like a pre-licenced copy, will download a demo copy and try that and let you know how it goes.
    cheers
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
