Thread: Old Guy Returning
10-02-2022 #1
Hi Guys
Old guy returning now im retired I have finally made a small plasma table for shed, only 540mm x 460mm cut area, small PC a NVUM controller and Mach3
running sheet cam and mach3 thc scriber as post,
have got all working eventually, sort of, apart from switching on plasma Mach3 says torch on but ill be buggered if i can work out how i can get a output to turn on a relay Help please if any one has any idea where or what im doing weong or missing, I hate bloody software
Thanks all
Steve
https://youtu.be/2huUEvnkJSM
13-02-2022 #2
Hi Steve,
Pushing F5 or calling M3 will turn ON or OFF the output number you set in the Spindle (plasma uses spindle M3) setup section of ports n pins. By default, I think mach3 is set to use Output #1
You can also edit the M3 macro and have it do whatever you want using VB code.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
13-02-2022 #3
NEW MEMBER: Hello People!! Returning to Engineering in my shed and garage!
By Ancient-Axeman in forum New Member IntroductionsReplies: 0Last Post: 06-11-2019, 03:43 PM -
Mach3 and returning to cut position
By dfox1787 in forum Artsoft Mach (3 & 4)Replies: 13Last Post: 07-07-2018, 10:06 AM -
Zero Postion Pointer are your steppers returning to zero every time
By Kev2960 in forum Metalwork Project ShowcaseReplies: 0Last Post: 08-10-2017, 05:33 PM -
machine cutting sequence, keeps returning to the original point
By luke11cnc in forum Machine DiscussionReplies: 3Last Post: 06-07-2013, 04:48 AM -
NEW MEMBER: Returning
By Leadhead in forum New Member IntroductionsReplies: 0Last Post: 14-08-2011, 09:40 AM
