    Take a detailed photo of the front of the drive itself showing the connection.
    I did find part number:
    10136-3000VE. Connector.
    10336-52A0-008. Shell.
    Conn part no, search, came up at RS components.
    Shown as discontinued product there.
    https://uk.rs-online.com/web/p/scsi-connectors/1761986
    Numbers were taken from manual for MSD series that came up when searching your drive number. Config looked the same 4 rows.
    Technically, there should be a part number for connector/shell in your manual either above or below the pin config image.
    Also part numbers for different encoder cable options depending on motor driven.
    Double/triple check any cables after soldering, with a meter.
    Quote Originally Posted by dazp1976 View Post
    The rows in the manual don't make sense as explained previously in my last reply to JAZZCNC.
    Also found this https://www.ebay.com/itm/30385701666...gAAOSwAxtgCptv
    The fact that this guy in the USA is selling generic cable for Yaskawa, Mitsubishi, Panasonic servos would also suggust to me a standard pin numbering for the port.
    Every time I am wrong - the World makes a little less sense.
    Quote Originally Posted by Nemo1966 View Post
    Ok, now I can see the connector properly I can tell you that it's exactly the same connector as the pics I posted.
    So in your original post, the 2nd pic is correct if viewed from the front. BUT the manual diagram is also correct when viewed from the rear of the connector as you would normally wire the connector.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    As in the 'plug-in to the drive' side is configured as long rows......
    The solder tabs on the back 'cable side' are configured as the diagram.
    Just make sure you solder the numbers in the correct order.
    I'd prob get a pre-made scsi cable at needed length and chop one end off. Then use a meter to mark up the pin numbers on the cut ends.
    That's me being too idle to solder though!.
    There are breakout /screw terminal connector pcbs you can use if you want to keep both ends of a cable intact.
    Like:
    https://www.aliexpress.com/item/3246...Adapt=Pc2Msite
    https://czh-labs.com/products/czh-la...QaAmniEALw_wcB
    Male or female depending on application.
  1. MSD043A1XXV Panasonic AC Servo Driver 400w - MB3 connection help
    By Nemo1966 in forum Stepper & Servo Motors
    Last Post: 22-05-2022, 05:58 PM
  2. Replies: 2
    Last Post: 27-08-2020, 07:54 PM
  3. Dc servo driver
    By Treemonkey in forum Motor Drivers & Controllers
    Last Post: 11-02-2013, 08:16 PM
  4. Panasonic 3 phase driver running on 1 phase?
    By gavztheouch in forum Motor Drivers & Controllers
    Last Post: 10-05-2012, 11:21 PM
  5. FOR SALE: 400w panasonic ac brushless servo motors and drives
    Last Post: 29-12-2011, 03:04 PM
