    Quote Originally Posted by masinecc View Post
    What min and max sand size ?
    It's already done for you inside the bags.
    Pre-mixed, just have to add water
    Quote Originally Posted by XYZ_Spec View Post
    Hi Lee, thanks...
    All the parts were made by this machine. It has evolved over the last year... It all started with a 3018 from aliexpress lol
    Understood, I went on to watch the vids after I posted, looks good :)
    Still what one did you use the finish looks really smooth, any tricks to that ?
    The mix is done with fine sand, that's why the finish is not rough. Applied primer, sanded a bit and then painted it. It's not that perfect, but the performance is what matters at the end. :)
  4. The Following User Says Thank You to XYZ_Spec For This Useful Post:
  5. #4
    Lucky you. Pms share the name on the mix, i wanna see the technical data sheet and see what i can find close to it locally
  6. #5
    Here it is the manufacturers site page for this product I've used.
    It seems to be only available in Portuguese language.
    This is the best I can do for you.
    https://www.cimpor.com/-/betao-seco-be-30
  7. #6
    Same...
    Thanks for sharing...
    What about this probe, how you finding it, accuracy etc?
    https://youtube.com/shortsNtOfxCaf4lU
    P.S Is it still v6: 3D Touch Probe Edge Finder ???
    Yes Lee, V6.
    I like it a lot, and it's not crazy expensive.
    I want to install it permanently onto the spindle mount, this will allow me to set zero without having to do a tool change.
  9. The Following User Says Thank You to XYZ_Spec For This Useful Post:
  1. Damping Test of Concrete & Steel Tube
    Last Post: 16-05-2022, 01:26 PM
  2. Adding a Laser to my steel and concrete machine
    By Bongo in forum Gantry/Router Machines & Building
    Last Post: 16-05-2022, 12:28 PM
  3. Machining lighweight (AAC) concrete blocks.....
    By Voicecoil in forum General Discussion
    Last Post: 03-07-2020, 08:32 PM
  4. FOR SALE: Snowcrete Concrete - 14 x 25 KG Bags
    By Chaz in forum Items For Sale
    Last Post: 13-04-2019, 04:32 PM
  5. concrete base
    By reefy86 in forum General Discussion
    Last Post: 04-12-2017, 09:55 AM
