    This was done on a KX1 mill as a test for someone who wanted to do roughly the same prototype boards with no lead time.
    Not knowing sod all about PCB's, only JCB's, I asked for a file, this was code generated direct from one of the PCB software packages.
    On the left is the code as sent but the tool depth was too deep so it was edited and the one on the right run again.
    You may recognised the pad layouts but as scale the holes which were in the scrap sample board are 3mm.
    A Krees spindle will cut these tracks with no problems, no bearing update needed, I do finer work than this with no problems.
    John S -
    This was done on a KX1 mill as a test for someone who wanted to do roughly the same prototype boards with no lead time. ..... You may recognised the pad layouts but as scale the holes which were in the scrap sample board are 3mm.
    Looks like 2.54mm pitch through-hole, and 1.27mm SMD. The job on the right is close to what I need. Do you happen to remember what tool you used to mill this?
    Just looked at KX1 specs - shame about the exchange-rate, because that would otherwise have been an option for me. The stated linearity and repeatability are well within my needs, and 180mm z-axis travel would be really useful.
  1. Board and Motors package - opinions sought
    By cropwell in forum General Electronics
    Last Post: 01-05-2014, 10:33 AM
  2. Bench lathe -opinions sought
    By cropwell in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 14-03-2014, 06:32 AM
  3. FOR SALE: Clarke CMD300 / Sieg X2 3 Axis Milling machine CHEAP
    By craigrobbo in forum Items For Sale
    Last Post: 28-07-2013, 07:54 PM
  4. Your views and opinions on the Black Cat CNC Machine 600x900 please
    By Rockeyes in forum Milling Machines, Builds & Conversions
    Last Post: 31-05-2012, 05:21 PM
  5. opinions on buying cnc milling machines
    By DGH in forum Milling Machines, Builds & Conversions
    Last Post: 27-05-2009, 04:47 PM
